1964 f100 stock Gauges
Does anyone know if the stock gauges for the 1964 f100 are being repopped by anyone? I can't seem to find anything other that after market such as dakoda etc.
My son just purchased a 64 short bed which has been for the most part untouched for 40 years. all stock, rebuilt 292 with great patina. I noticed that the prev owner had some gauges mounted under the dash, so I'm assuming the stock gauges are not working. We've not fired her up yet, so not sure but wanted to check and see if anyone is remaking the stock gauges.
thanks
thanks
I don't know of anyone who sells reproduction gauges, but working originals show up on eBay pretty regularly.
The gauges are fed power by a constant voltage regulator (CVR) behind the dash, which is reproduced (about $30). CVR's are far more fragile than the gauges, so it's worth replacing--the gauges may come back to life. (Even if they don't, you'll want the new CVR powering your replacements as well.)
If you're willing to build this:
Vintage Thunderbird Club International :: View topic - Making a bench testing power supply from a computer P/S
You can test your gauges (and many other things) on the bench.
3.3 Volts applied to a temp gauge for my 62.
Good luck.
~Steve
Good luck.
~Steve
His 64 probably has the round speedometer
He might have a generator
A separate oil pressure gauge to the right of the main speedometer, if his and yours both had one, would be about all that would interchange with no difference.
Make sure the original gauges &c are bad before getting too spooled up... Wish I had a nickel for everytime a previous wrenchbender thought a part was bad and really wasn't. I ain't cheap, but no use replacing serviceable parts. This stuff is about as simple as it gets, no scan tool required! On a 64, every single SAE connector, grounding point and lugs will need cleaning down to bare metal, guaranteed.
First see if the gauges will peg when grounded. Another trick, crack the sending units loose and retighten. They get corroded and will go wonky without a good ground. The CVR is just a bi-metallic ON/OFF strip, it averages around 5 volts out of 12 volt input. It's fun sometimes to troubleshoot things that won't kick my *** and cost $900
gogoat
07-02-2018 11:53 AM
Glockem45
11-02-2008 02:21 AM
