1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Am I getting the alignment runaround?
Old 08-07-2014, 08:59 AM
Mystic_Cobra's Avatar
Mystic_Cobra
Mystic_Cobra is offline
2009 SRW 4x4
Dealer image shows 2008-2011 F350 4x4 SRW being the same.
My local dealer has my truck and is doing an alignment. It's never been done in 85000 miles. They are replacing the steering box and recommended an alignment. Since, it had never been done, I decided to do it.
After checking, he says they need me to buy a shim kit in order to get the alignment into specs. The truck is completely stock. Says the shim kit is $80 more PLUS installation.
He sent me a pic of the current alignment:
FRONT
CAMBER: L 0.4 R 0.2 * in the green range
CASTER: L 4.1 R 3.9 * both in red as alignment range is up to 3.9 deg
TOE: L 0.17 R 0.19 * left is green and right is red as range is up to .18 deg
All values positive.
Is already charging me $180 for the alignment which I think is ridiculous. Why would a stock engine need a shim kit to align it?
I understand alignment specs so I know what it all means. I don't understand how a stock truck would need a shim kit to get it aligned.
Old 08-07-2014, 09:34 AM
Kdr358's Avatar
Kdr358
Kdr358 is offline
The shim kit could be to adjust for the worn/settled suspension components.
What exactly are they trying to shim?
Old 08-07-2014, 10:04 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
If they need to compensate for worn suspension, or bushings/ball joints of any kind, why wouldn't they repair those? Would fix the alignment issue and restore the truck to its proper condition.
Old 08-07-2014, 11:32 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
so for an f-350 its 180+80 at a dealer...I dont see that as expensive since a barebone alignment on a car at any major non oem repair shop is around 89 bucks plus the cost of end rods which seem to be a common replace item....benifet of what you are doing is that the folks you are dealing with are ford trained....if they need a shim kit...they would know...can you have what remains from the kit? maybe you can sell the extra shims?
Old 08-07-2014, 12:17 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
If by "shims" they mean the alignment bushings, then other than $80 being rip-off pricing they're necessary because the original bushings aren't adjustable. As far as alignment adjustments, caster and camber are set by the upper ball joint bushing, unless you want to get into radius arm or spring adjustments.
I don't have the '09 specs right here, but on my '07 with the same front axle the caster spec is 3.3*+/-1.2*, so eh, let that ride, and have them fix the toe, a little positive caster never hurt anyone if it still steers good. If you have one of the special front end packages with heavier springs, it's 2.6*+/-1.3*.
Old 08-07-2014, 01:48 PM
artguys's Avatar
artguys
artguys is offline
Fact #1. More mis-alignments are the result of a shop selling/performing a alignment that isn't needed.
FACT #2. Next time your at a alignment shop ask how often they re-calibrate their equipment...real truth is, they don't ever, when in fact depending what type it should be done every week to once each month.
Fact #3. Most alignments are performed by people who aren't qualified.
Fact #4. I hit a pot hole, need to get the alignment done...when the answer to that would be never. Vehicle manufacturers DO NOT(in case you didn't read it right) DO NOT make vehicles that just go out of alignment, even when hitting a pot hole...make that 5 pot holes is succession. It takes severely worn or damaged suspension or steering linkage parts, a suspension sag/ride height or the ever more present, the last guy to touch it problem.
Your instincts are correct.
I specialized in and owned a specialty vibration/alignment business for many years. The bulk of my business was repeat and those problems that arose from substandard shops.
Old 08-07-2014, 01:53 PM
Mystic_Cobra
My original post has the specs in my comments. Specs say up to 3.9 deg positive caster is good but 4.0 is out of spec.
The service writer initially said the shims were needed to get the camber into spec but they clearly show that the camber is IN spec. So, he was wrong. He also admitted (on the follow-up call) that I knew more about alignments that he does. I'm a road racer and do my own alignment adjustments on my racecar.
He didn't say exactly what they were trying to shim and it sounds like he didn't know.
After giving me time to look at the "before" alignment settings, he did call back and told me it was done. I was like, "oh, ok, so we did we do about the shims?"
He said they went ahead and aligned it best they could without the shim kit.
He sent me another picture of the screen showing the "after" settings.
"AFTER" FRONT
CAMBER: L +0.5 R +0.2 * both in the green range
CASTER: L +4.0 R +4.0 * both in red as alignment range is up to 3.9 deg
TOE: L +0.08 R +0.07 * both in the green as toe variance is -0.08 to +0.18 deg
So, this tells me that the caster, not the camber needed the shims to get into alignment which makes more sense to me. My 65 Mustang took shims to align it and I'm pretty sure they were for caster. As a road racer, the positive camber makes me cringe so I'll just have to take it slow through the turns. But we run as much positive caster as possible as long as both sides are the same on Mustangs (in the 4-7 deg range).
So, from before to after, the camber and caster are virtually the same, and the toe has been corrected by about a tenth.
It doesn't seem right that I should have to pay for the alignment at all but he says the Ford extended service plan doesn't cover the alignment with a steering box replacement. Does that sound right to you guys?
Old 08-07-2014, 01:55 PM
wizkid00104's Avatar
wizkid00104
wizkid00104 is offline
These are the adjustable bushings. Just put them on my Ranger and they work wonders. I have been given the alignment runaround which is why I bought these and did my own alignment using a $10 protractor from sears and a few string line levels.
Federal-Mogul eCatalog Resource Center
These bushings let you adjust castor and camber independently (center hex turns inside the outer hex) where as the stock bushings can only do camber and castor in relation to one another.
If you choose to do it yourself, take it to a shop with the laser alignment machine and just ask them for a printout of where your alignment is and you can then adjust it base upon the readout. My shop will set the toe for me while it is on the laser machine since it is more accurate than a tape measure.
Old 08-07-2014, 01:58 PM
artguys's Avatar
artguys
artguys is offline
There was nothing wrong with the original specs...you wouldn't have any handling or tire wear issues with those readings. And no, I would've played hard ball and refused to pay it.
Old 08-07-2014, 02:01 PM
artguys's Avatar
artguys
artguys is offline
I would be fairly certain you had to deal with a service writer, not only do they not know enough about what's happening but I would be very suspect of the person performing the so called alignment.
Old 08-07-2014, 02:04 PM
Mystic_Cobra
So, it sounds like you are suggesting that neither one of them is qualified for their job?
Old 08-07-2014, 02:07 PM
artguys's Avatar
artguys
artguys is offline
You can make that judgement...I can only state that in my years in dealing with like cases that what I stated earlier is most often the truth.
Old 08-07-2014, 07:15 PM
The Kaz's Avatar
The Kaz
The Kaz is offline
I think fact#3 is 90% of the problem
Old 08-07-2014, 08:17 PM
Denola's Avatar
Denola
Denola is offline
He ain't lying! With the way the SuperDuty suspension and axles have all the degrees of caster and camber bent into the components, unless you have worn parts, leave it alone. The toe-in is the most important adjustment on these trucks. I give mine 1/8" toe by letting it sit on the ground and measuring with two, wooden yardsticks, zip tied together (where they will slide in and out). visual inspect the gap between the sticks and the inner side of the tires, forward and after the axle. Drives great, wears tires like it should, and have not spent a dime.
Old 08-07-2014, 08:19 PM
senix's Avatar
senix
senix is offline
Received 1,415 Likes on 1,010 Posts
Next time take it a truck shop. I take mine to where they do the big rigs. Better, larger racks to check the alignment properly.
BTW my car has 102K on it no alignment. Truck is too new for one.
Quick Reply: Am I getting the alignment runaround?
