6.4 antifreeze 2010 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 antifreeze 2010
Old 08-06-2014, 10:55 PM
Duhnis Duhnis is offline
Duhnis is starting off with a positive reputation.
6.4 antifreeze 2010
Hi All,
I recently bought a 2010 f-250 with a 6.4.
I want to change all the fluids, filters to start the maintenance program .
Since I work at John Deere and deal with Tier 4 engines , I was wondering your thoughts as to using the yellow J.D Cool-Gard II antifreeze. Designed for use in Tier 4 diesels and good for 6 years. ( with proper conditioning)
Thoughts??
Or should I run the red Rotella ELC ?
Thanks,
Duhnis
Old 08-07-2014, 05:20 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
most have stuck with the ford gold coolant and it has worked well. You just need to check the nitrites every so often.
Be sure to use only OEM fuel and oil filters on this motor.
Old 08-07-2014, 07:41 AM
sxrfun sxrfun is offline
sxrfun is gaining momentum as a positive member of FTE.sxrfun is gaining momentum as a positive member of FTE.
I switched to the Rotella ELC about a year ago....good coolant and pretty much worry free for the life of the truck. Also no chance of silicate dropping out and clogging your oil cooler.
Old 09-02-2014, 09:23 AM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Quote:
Where did you purchase the shell Rotella ELC?
Old 09-02-2014, 01:41 PM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.
As Senix stated stick to the factory fuel and oil filters. Aftermarket just don't seem to fit right and i personally have had issues with them. As for the coolant i use
http://www.cumminsfiltration.com/pdf...LT15070-GB.pdf
We had a problem with our guys mixing coolants of different types because we have so many different pieces of equipment and trucks. In addition each manufacturer claims you need to run a specific coolant. This coolant mixes with all the different machines we have so we eliminated the issue. The coolant is working well for us with no issues, but review it to make sure its right for you before you consider it.
Few quick tips:
1. Follow the severe maintenance schedule
2. Test the nitrates in the coolant frequently
3. Don't idle the truck excessively
4. Use quality fuel from a known source ( The fuel systems on these engines are not forgiving to water in fuel)
5. Watch your oil level to make sure its not growing. ( Can be an indication of fuel in the oil. The DPF emission system's on these engines can attribute to additional fuel in the crankcase which can result in additional wear or failure on engine components if left unnoticed. )
Optional:
1. Use a good fuel additive such as Opti-Lube Diesel Fuel Improver | Grease | Oil Fortifier
2. Use synthetic oil CJ-4 approved
3. Take Oil samples
Old 09-02-2014, 03:02 PM
Quote:
Canadian Tire is where I got it. Not sure if they still carry it though.
Old 09-02-2014, 03:05 PM
RM2738's Avatar
I just found a vendor online that may have a Typo on their site. They list "6 gallon case" @ $14.99 TOTAL. just ordered so let's see....
Old 09-02-2014, 03:19 PM
RM2738's Avatar
So after doing a little research, Shell ELC doesn't provide a Ford rating but does provide a Cummins rating of 14603 in which Motorcraft Gold coolant confirms to. BUT, Only the ULTRA ELC meeting the Cummins rating. Rotella ELC has a rating of AEB 90.47. So is it recommended to go with the ULTRA ELC?
Old 09-02-2014, 06:57 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
Ill take a PM on that.....
Old 09-02-2014, 07:04 PM
RM2738's Avatar
Quote:
They cancelled my order and refunded my money due to website error.
Old 09-02-2014, 07:17 PM
slowmans's Avatar
Old 09-02-2014, 10:09 PM
RM2738's Avatar
Which will probably work out for the better. Ultra ELC seems to meet the Ford spec much more than the regular ELC
'16 f-750 speed limiter Duhnis Large Truck 2 01-20-2017 08:14 PM
BEST TUNER FOR DPF/EGR DELETE Duhnis 6.4L Power Stroke Diesel 0 11-23-2016 09:45 PM
Trans issue? Duhnis 1999 to 2016 Super Duty 0 11-01-2016 08:10 PM
fuel additive / 2 stroke oil Duhnis 6.4L Power Stroke Diesel 16 09-08-2014 05:59 PM
Top Tier Gas? SMarquez Modular V10 (6.8l) 3 09-08-2010 06:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
