351 Cleveland help
Old 08-06-2014, 02:09 PM
51 F3 owner's Avatar
51 F3 owner
51 F3 owner is offline
351 Cleveland help
I have just rebuilt a 71 351 Cleveland and need some help, I have no oil pressure on starting, I let the engine run for about 30 sec. And still no pressure, I primed the oil pump and have oil coming up from the rear oil pressure sensor area when I spun the oil pump with a drill prior to starting, but still no pressure, did I miss something, the galley plugs were removed and replaced with new plugs after having the block checked and cleaned..
Old 08-07-2014, 10:47 AM
baddad457's Avatar
baddad457
baddad457 is offline
Sounds like you missed installing a galley plug or one popped out. Flow and pressure are two different things. You can have flow without pressure, but not the opposite. Try installing the pressure line at the front port (above the fuel pump) and see it it's got pressure there. Might be time regardless to pull the timing cover and intake to verify that the galley plugs are still in place.
Old 08-07-2014, 05:39 PM
51 F3 owner
How long does it take for oil to come up to pressure on a new rebuild after priming the oil galleys, I will check the pressure at the front oil plug, Thank You for all of your help.
Old 08-08-2014, 12:33 PM
baddad457's Avatar
baddad457
It takes awhile for it to reach the rear, bout as long as it does to get up to the rockers through the pushrods. That rear port is the "end of the line" for the oil passage system. If you're going to run it hard, it's not a bad idea to run an external line from the front port to the rear to insure equalized pressure to the rear main bearing.
Old 08-08-2014, 01:39 PM
0ldman's Avatar
0ldman
0ldman is offline
Just about the only engine we didn't user plastiguage on was my escort when I was a kid. I got a 10 under mains and a bad crank. We even went to 20 under mains and still had no pressure. Had to swap the crank, rod and main bearings, warranty of course.
Did you check yours while you assembled it?
Old 08-13-2014, 02:10 PM
51 F3 owner
Thank you all for your help, had a loose galley plug, and a dumb mistake on my part, the remote oil filter lines were backwards, I got 25- 30 psi at 2000 rmp's at the front and rear pressure guage, again thank you for all of your help
Dave
Old 08-15-2014, 04:12 AM
baddad457's Avatar
baddad457
Yea, crossed up cooler lines will get you a zero reading everytime. Done that once with my V8 Ranger. "Out" goes to the "IN" port.
51 F3 owner
08-06-2014 05:54 PM
51 F3 owner
08-06-2014 02:40 PM
Dog_Brains
07-07-2001 10:11 PM
JSWF100
05-04-2000 09:54 PM
Quick Reply: 351 Cleveland help
