over starting issues - Ford Truck Enthusiasts Forums
Old 08-06-2014, 11:32 AM
1KILLERZ's Avatar
1KILLERZ 1KILLERZ is offline
1KILLERZ is starting off with a positive reputation.
I have a 1978/79 bronco with a 429 in it.
Having issues with the truck trying to continue to try and turn over once the key is disengaged. I have removed the solenoid from the inner fender, cleaned the mount surface, and reattached. I was told if this ground area was bad, the truck would do as described. Yet after doing this area, the truck just yesterday did the same thing again.
am I missing something?
Thank you.
Old 08-06-2014, 12:18 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
you may have to pull the starter and have it tested. are you running headers? perhaps its getting to hot
Old 08-06-2014, 12:27 PM
1KILLERZ's Avatar
Quote:
Running manifolds actually. Thank you, I may just do that. Cant go trail riding like this.
Old 08-06-2014, 01:47 PM
blackjack33's Avatar
blackjack33 blackjack33 is offline
blackjack33 is gaining momentum as a positive member of FTE.blackjack33 is gaining momentum as a positive member of FTE.
How's the condition of the solenoid, is it the factory OE unit? Sounds like you're on the right track with the solenoid.
Next time that happens, lightly tap the top of the solenoid with the handle of a screwdriver and see if that helps.
You may end up replacing the solenoid, get the best one that you can afford.
Take a look here it's a good explanation of what's happening in situations like this.
Old 08-06-2014, 01:52 PM
1KILLERZ's Avatar
Replaced already. I believe I was running the original. Yea, this may explain everything. Thank you for the link. Hopefully fixes issues and I will be back out on the trail this weekend.
Old 08-12-2014, 02:49 PM
1KILLERZ's Avatar
update
Pulled the older unit solenoid, with a quality unit. Checked all wires, etc. The new, quality unit then did the same thing. :/
We left it hooked up, pulled the ignition lead wire from the solenoid, and it stopped cranking. Appears the ignition/key switch is the culprit here. Bummer, missed a weekend to go wheeling. Oh well, summer is not over yet.
paint not sticking on cowl area bigcrunch 1973 - 1979 F-100 & Larger F-Series Trucks 13 02-09-2016 07:07 AM
Trustworthy/ reccomended shops in the DC area Martin97C5LS1 1999 to 2016 Super Duty 0 04-23-2015 12:33 PM
Looking for a mechanic in the SF bay area ddeflyer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 03-02-2015 04:25 PM
My 65 brakes tbm3fan 1961 - 1966 F-100 & Larger F-Series Trucks 10 11-11-2014 08:55 AM
5.4 Triton issues multi issues. f350hammer General Automotive Discussion 7 07-22-2014 06:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
