01 Sport trac door lock issues - Ford Truck Enthusiasts Forums
Old 08-06-2014, 09:47 AM
Jeffrey w Jeffrey w is offline
Jeffrey w is starting off with a positive reputation.
only the driver door unlocks, front passenger and both back doors will not unlock. I have a Fob and both unlock switches will only unlock driver door. All 3 will lock all the doors but only the driver door unlocks
Old 08-06-2014, 11:54 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
It sounds like this could be an issue with the unlock relay that switches the polarity for unlocking the non-driver's doors. There is a separate relay for the driver's door for the "Priority unlock." Since the fob doesn't work to unlock the other doors the issue is probably not a broken wire in the accordion boot between the driver's door and the cabin. The remote keyless entry system does not rely on those wires for the other doors.
I'll have to check the service manual to determine if the unlock relay for the other doors is built in to the remote keyless module or if it happens to be separate.
-Rod
Old 08-06-2014, 12:19 PM
Rod,
Thank you. I have looked and cant find a relay for the door locks
Old 08-21-2014, 10:21 AM
Shorod,
Did you find anything?
Old 08-21-2014, 12:53 PM
shorod's Avatar
Oops, I forgot all about this. I'll try to remember to look tonight. If you send me a Private Message or reply to this thread I should remember to check tonight.
-Rod
Old 08-21-2014, 07:47 PM
shorod's Avatar
Per the factory wiring diagram for the 2001 Sport Trac there are 3 relays for the power locks, and all three relays are located in the Auxiliary Relay Box #3. There is a Driver Door Unlock relay (K131), a Door Unlock relay (K129), and a Door Lock relay (K130).
It appears however that the driver door unlock relay is ONLY activated by the Remote Keyless Entry module, so since the driver's door unlocks with the Fob or door switches, that indicates the Door Unlock relay AND Driver Door Unlock relay are both working fine.
About the only place you could have an issue would be with the splice from the unlock relay to the liftgate lock and passenger door lock. Looks like you might get to go wire loom fishing to try to hook the pink/orange unlock wire.
-Rod
Old 08-25-2014, 11:40 AM
Thank you, can you tell me where relay box #3 is located
Old 08-25-2014, 09:58 PM
shorod's Avatar
You might need to check the owner's manual to see if it explains the location. If you don't have an owner's manual you can download a PDF of it here.
The service manual only lists the location for the Sport. I suspect it's different for the Sport Trac. For the Sport it lists LH rear of vehicle. For the Sport Trac that would put it in the bed, I doubt that's accurate.
-Rod
ford f350 2003 crew cab power lock problems fruitcake1234 1999 to 2016 Super Duty 1 10-15-2013 06:04 PM
remote door unlock fob issue. swoosh 1999 to 2016 Super Duty 2 07-30-2013 03:50 AM
drivers door will not unlock toddrochester Explorer, Sport Trac, Mountaineer & Aviator 28 01-20-2012 06:33 PM
Doors will lock, won't unlock. Not the actuators. Wren Excursion - King of SUVs 8 02-03-2009 08:11 AM
1996 ford explorer, unlock door button problem jlitz Explorer, Sport Trac, Mountaineer & Aviator 9 03-16-2004 11:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
