Ignition Coil Connectors - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 08-06-2014, 10:38 AM
greatestNothing greatestNothing is offline
greatestNothing is starting off with a positive reputation.
Are these repinnable? I just replaced plugs(only broke 2 yay) and COPs...have 4 of these connectors that the wires won't stay seated in. If I go grab some from the junkyard, can I push the wires into them and not have to splice them?
Old 08-06-2014, 05:19 PM
NLPRacing's Avatar
NLPRacing NLPRacing is offline
NLPRacing is starting off with a positive reputation.
Are you talking about the just the boot from the coil to the spark plug? If so, just go buy some new ones, they are only a few dollars each and I've seen a set of 8 as cheap under $25. I always replace the boots when I have the plugs replaced.
Old 08-06-2014, 10:17 PM
Nope, not the boot. The 2 wire connector. I picked up one from Napa and was able to remove the wires and put the factory wires back in..I don't want to end up paying 200 dollars total for eight of them..might just buy the whole harness from stealership for 230...
If anyone's wondering don't buy Chinese coils, you'll pay more in the end.
66 Ford F100 wiring connectors jasindude1 1961 - 1966 F-100 & Larger F-Series Trucks 5 04-04-2016 09:48 PM
Wiring Harness Connectors nrbacarl 1999 to 2016 Super Duty 9 04-04-2016 02:26 PM
What type of wire connector is this? Like M. Fords Electrical Systems/Wiring 1 06-09-2015 03:03 PM
Battery Terminal Connectors jax2002f150 1997 - 2003 F150 2 12-27-2012 12:24 AM
7 way plug problems metriccar Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 4 05-01-2012 07:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
