1988 F-150 2WD to 4X4 Conversion - Ford Truck Enthusiasts Forums
Old 08-05-2014, 11:59 PM
BS51993's Avatar
BS51993 BS51993 is offline
BS51993 is starting off with a positive reputation.
I have a 1988 F-150 with a 4.9L inline 6 and 3 speed manual. It is 2-wheel drive and I have been considering doing the conversion to make it 4-wheel drive. The inline 6 has been a very reliable engine for me, but I'm not sure if I should keep it if I do the conversion. If not, I will likely swap it for a 5.0 V8. Has anyone done a conversion on this type of truck? If not, what are your opinions on this?
Old 08-06-2014, 12:39 AM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
Unless the truck has a perfectly clean body and frame, or some significant sentimental value to it, your better off buying a 4WD truck. To do the conversion properly you will need an entire donor truck that has the same cab and bed configuration as your current one. You need the front axle and related parts, the driveshafts, transmission, transfercase and a couple other small bits and pieces.
Old 08-06-2014, 02:41 AM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
^^^This^^^
It's not like 4wd bricknose 4WD trucks are that hard to get your hands on. Were not talking about a 61 slick here or anything.
Old 08-06-2014, 10:55 AM
1995F150XLT4x4's Avatar
1995F150XLT4x4 1995F150XLT4x4 is offline
1995F150XLT4x4 is gaining momentum as a positive member of FTE.
Evan said it all.
1988 f150 engine swap thoughts Gabcar8321 1987 - 1996 F150 & Larger F-Series Trucks 15 03-04-2017 08:22 AM
Body/Chassis Swap 1989 E150 to Quigley Chassis. Redinwolfe 1968-2013 Full Size Vans 30 06-05-2016 07:54 PM
Western Snow Plow Plumberdude3 1999 to 2016 Super Duty 2 04-04-2015 05:54 AM
1988 E150 Conversion Fuel Pressure Issues dgeist 1968-2013 Full Size Vans 60 02-15-2014 09:50 AM
carter yf and yfa help and Facts 1985tullyhowell 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 12-12-2013 08:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
