OBD code 171, 174 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
OBD code 171, 174
Old 07-11-2003, 05:04 PM
Houndog101 Houndog101 is offline
Houndog101 is starting off with a positive reputation.
OBD code 171, 174
The wife's Expy,, developed rough idle, then check engine light..Pulled codes 171, 174..Can anyone help??
Thanks Ted
Old 07-11-2003, 07:25 PM
Rtpjunior Rtpjunior is offline
Rtpjunior is starting off with a positive reputation.
OBD code 171, 174
Code 171 and 174 are for bank 1 and 2 running too lean. The engine has compensated as rich as it can go, and it is still to lean. This does not necessarily mean your mixture is bad, but something (a sensor) is telling the ECM to correct lean. The oxygen sensors alert the ECM to how lean/rich the exhaust is, and then the ECM trips a code. Maybe you have a bad oxy. sensor, but since there are 4 of them (2 per bank), I don't think they could all go at once.
Old 07-11-2003, 07:44 PM
fte fte is offline
fte is starting off with a positive reputation.
OBD code 171, 174
I had the same codes come up and it wasn't the sensor but it was the hose from the pvc valve to the intake system. It had small pin hose that was letting air into the system as was making my truck idle bad. Feel around to the back of the hose behind the air intake.
Old 07-11-2003, 07:48 PM
OBD code 171, 174
Quote:
FTE is right, I forgot about that. I had the same engine issues, but not as bad. My PCV hose looked like it had been in the microwave for 20-30 minutes and barely allowed any air through it.
Old 07-12-2003, 05:44 AM
OBD code 171, 174
Thanks Guy's for the quick response..I'll check that out this AM..
Old 07-14-2003, 06:58 AM
Unhappy OBD code 171, 174
Can not find any leaks in the intake system,,any other ideas ?
Thanks..
Old 07-14-2003, 02:51 PM
RADVRA RADVRA is offline
RADVRA is starting off with a positive reputation.
OBD code 171, 174
This appears to be a common problem!...I also have a 1998 Expedition EB 5.4L Triton (77k miles), and have a rough idle and "check engine" light warning. I just wanted to thank you all for this forum and great ideas that are shared. I am headed to Autozone this afternoon to see if I can get a code check to determine if I need to replace O2 sensors MAS, or a PVC valve (haven't inspected this yet).
The thought of taking my truck to a dealer and paying through the nose to fix this problem lead me here (that and the realization that I was looking at 4 O2 sensors to troubleshoot!). I appreciate the info that you all provide!
Question: Are the O2 sensors hard to get at/replace?
Old 07-14-2003, 03:51 PM
OBD code 171, 174
Quote:
Thanks..
The PCV may look OK, but you have to trace the tubing back around to the back of the motor. It connects to the intake manifold with a small rubber elbow. This elbow, over time deteriorates from the heat inside the engine compartment. If you gently squeeze the elbow, you will feel the damage to it, it's probably cracked. It is almost impssoble to visually inspect due to its location. Check this out before going further, it may save you some $$$.
Old 07-15-2003, 06:09 AM
OBD code 171, 174
Thanks Rpt,,I'll check it tonight..
Old 07-16-2003, 03:53 PM
Talking OBD code 171, 174
Replaced the PCV assembly and hoses,,That fixed the problem..Thanks Again for the help..
Old 08-26-2003, 12:28 AM
worshiper worshiper is offline
worshiper is starting off with a positive reputation.
Lightbulb OBD code 171, 174
Thanks for the thread guy's. My 97 E350 check engine light came on 2 weeks ago. After replacing 2 O2's I looked here and found my PVC elbow was bad (it did look like it had been in a microwave)
Autozone's OBD said it was too lean, but no code. O'Riley's machine give me a code of 171,174. That's how I found this thread. If I looked here first, I might have saved $100.00 bucks.
Extreme pinging and no power with codes, 125, 153, 401, 171 and 174. Corey Zion Modular V8 (4.6L, 5.4L) 0 12-13-2016 06:54 PM
Codes PO401, 171 and 174 RDockery 1997-2006 Expedition & Navigator 3 05-27-2016 12:19 PM
DTC 171 and 174 Shanemh 1987 - 1996 F150 & Larger F-Series Trucks 12 10-19-2010 10:22 PM
help with code 171 and 174 kkdad Ranger & B-Series 3 04-15-2006 04:57 PM
check engine code 171 and 174 1997 ranger 97 ranger 1 Ranger & B-Series 7 06-26-2005 07:04 PM
Tags
04, 171, 171174, 174, 1997, 54triton, code, code171, codes, expedition, ford, lincoln, navigator, ob2, obd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
