The Carnage Has Begun
#136
Fire truck or water hose used to put out the fire? Moisture sitting on the walls of those walls or inside that engine? Doesnt take much on a Diesel but a few drops to bend stuff on the bottom end. Hell even gas will do the trick. And bend a rod and or crank. I know cause I was a Mechanic in the Army and operators would do it all the time.
#137
#138
#139
#140
#143
[QUOTE=Dan V;14651250]That price point just isn't possible...heck the rebuild kit from RiffRaff is that much...with no machine work.[/QUOT
Seems to me you need the pistons to get a good bore job. Riffraff kit has everything, all gaskets, etc., I would think balancing should be included for that price also. If there just hot tanking, boring and putting in cam bearing its to high.
#144
Thanks. To be fair, the upper crossmember is out. I don't think it would come out and go in with that in place.
#146
#148
#149
Pikachu,
Looks I like I'm going down the same road right now but mine has a spun #6 rod bearing. Looks like we shopped at the same store for the cherry picker and engine stand. I've gotten everything down to the bare block right now and ready to start checking crank and cam, etc. Where did you find the engine spec's for what's standard and how much wear is acceptable? I've tried to search the internet but haven't had much luck. Do you have a spec sheet you could send? Thanks
#150
I am glad you at least got the truck back on the road. Sure the engine might have issues but the truck is rolling down the road.
