85 f150 spark plug issue
I recently bought a 85 f150 302 FI, at least that's what the data plate and the VIN says. I was doing some tune up on the truck and bought spark plugs (motorcraft ASF32C.)
The data plate on the truck said this was what went with the motor same with searches at the auto parts store. Tried installing them and they won't fit. I checked the part number on the old spark plugs and they were autolite AP104.
From my searches it looks like that's a plug for a ford 4.6, and that they are not for a 302. Am I wrong, and is it possible someone did an engine swap and kept the old intake? This is my first ford and I have no clue how to tell the difference between the different ford v8s. Any help would be awesome, thanks!
The ASF32C has a 5/8" hex, 14mm thread, with a .460" reach;
the AP104 has a 5/8" hex, 14mm thread, with a .708" reach.
So the main difference is the reach (how long the threads are - or how far the plug reaches into the head).
So why didn't it fit. either plug should have threaded right in as they are the same size threads. BTW- the reach is important. Too short, and the electrode won't protrude into the head (so the spark will be up in the head/threads), too long and carbon will build up on the exposed threads and you will/may strip the threads trying to get it back out later (and it could hit the piston).
That what I figured, I wasn't sure but I didn't think the old FI system would work for a motor that would have a more modern ignition system.
Not sure if they're aftermarket they don't quite match the wear on the motor so they might be.
I believe they're not long enough, it seems like they might be bottoming out before in can thread anything in. Exactly, that's what I'm a little worried about is if the last guy who owned it screwed up the motor putting the wrong plugs in.
It looks like a stock 5.0L (302) to me. If the heads were changed at some point, my bet is they went back with stock. The engine doesn't show the external modifications that someone would be expected to do if they were putting on a set of performance heads (like upgrading the air intake).
I think the last guy installed the wrong plugs.
You may want to run a "thread chaser" to clean up the threads. Perhaps there is carbon build up making the plugs thread in hard.
You could check the plug reach with a bent piece of wire. Insert it into the cylinder and then catch the back side of the threads. mark the outside of the wire where the threads start, then remove the wire and measure from your mark to the bend. If you do this be sure to use a long piece wire (like mechanics wire) so if you drop it, it doesn't end up in the cylinder where you can't retrieve.
Was doing some looking around and it looks like the gt40 heads use the same plugs, just wanted to double check if I'm right. If they do is it possible the old owner took some used heads and put them on there and is there a way to tell the difference between the original heads that would've been on and the gt40 heads?
Maybe a "quick and dirty" check would be to determine the plug reach as discussed a few posts back. Based on the plug research you did, the GT40 heads have a plug reach of almost 3/4" where the stock heads have a reach of under 1/2". It shouldn't be too determine to see what "plug reach" your heads have.
