It comes out with all the wires for the blower motor and resistor, it should be a white hose but maybe also black, the main vacuum hose goes into the cab with these wires also
Thanks ifrythings, I guess I am missing it then. I have a black vacuum hose that comes from the cab to actuator and thats it. so if I get some vacuum hose where does it go, anyone??
The actuator is for your AC fresh /recirculate air door. Move the selector on the dash to Max AC and hose should have vacuum. It connects to a small metal tube on the actuator. Vacuum applied will move the door to recirc and no vacuum and the door stays in the fresh (outside) air position.
I just found it, I guess the po folded it up and taped it up in the wire loom. I just need to get a rubber hose that will connect it to the actuator. Thanks for all the help.
