V/b spring confusion - Ford Truck Enthusiasts Forums
Old 08-05-2014, 01:17 PM
Curjo Curjo is offline
Curjo is starting off with a positive reputation.
Ok, first let me say that I have been reading up as much as possible on this swap over the last few days and I am still confused after reading all the diys and articles. There are alot of threads on the subject I know.
The question I have is when finding used springs will the springs off any 2000-2005 4x4 f250/350 work? I have two guys parting out f350's in my area but neither know the code off the springs and are unwilling or unable to look for me. The first is a 2003 f350 and the second a 2004 f350 FX4. I'm trying to get a good deal by letting them bid against each other I just want to know if both will work. Thanks! Btw I have a 2000 ex 4x4 limited. Just bought it on Saturday.
Old 08-05-2014, 06:01 PM
Krazee Matt's Avatar
Krazee Matt Krazee Matt is online now
Krazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputation
Offhand I'd say the FX4 ones would be better but I have no idea for sure. If they're local why not just swing by and look at the door jam sticker? Spring codes should be listed there IIRC.
wrxin wrxin is offline
wrxin has a great reputation on FTE.wrxin has a great reputation on FTE.wrxin has a great reputation on FTE.wrxin has a great reputation on FTE.wrxin has a great reputation on FTE.
Yes you can use leaf springs off any 2000-05 F250 or F350 Super Duty 4x4. That's what the spring swap is all about. If you can't get the spring codes off the door pillar sticker, you're rolling the dice as to what you're going to get. Whatever the donor springs are, they won't the same as your X factory original springs. You'll probably have to install them, see how your X sits, and go from there.
The F350 blocks are quite handy if you can get them but you'll definitely have to do some work to raise the front more than just the donor spring.
Depends on what your lift goal is.
Also, make sure you read up on things like shocks and u-bolts.
Old 08-05-2014, 06:02 PM
Quote:
Also what Matt said. No idea about FX4 springs.
Old 08-05-2014, 09:24 PM
The guy with the fx4 just told me that it was painted over. Thanks for the help guys, I guess I'll just go with who I can knock down in price the most. Wrxin, my main goal isn't necessarily to lift it, it's to help out with some of the wander that I'm getting. Gonna tighten the steering box tomorrow to see how that works. This site is awesome btw, so much information!
Old 08-05-2014, 09:59 PM
RobRoss's Avatar
RobRoss RobRoss is online now
RobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud of
Quote:
If you can get the vin I can tell you what was on the truck when built. Or, if you can look at the springs, the part number is near the spring eye. Either way I can tell you what the spring is.
Old 08-06-2014, 12:14 AM
Be careful with the steering box. It's very easy to over tighten it and it's not usually the cause of wandering. Before lifted our X I had the most luck improving steering with a new steering stabilizer, a good alignment and the right tire air pressure.
Old 08-06-2014, 03:32 PM
holeshotwalt's Avatar
holeshotwalt holeshotwalt is offline
Spooled Up, Throttle Down
holeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to behold
Thumbs up Excursion suspension
Also, I would definitely get the rear sway bar off one of those one tons. Even if your X has a rear sway bar, it's probably a 26mm one. The one ton bar is 30mm and will bolt to your existing hardware (or get the end links and all from the donor truck if your truck has none).
It made a huge difference on my 03 that came with none!
Old 08-06-2014, 03:34 PM
Thanks for the advice! Btw, how much is everyone paying for used springs?
Old 08-06-2014, 03:53 PM
I got mine from Pick n Pull on a 1/2 price weekend, so they were unbelievably cheap... 80 for springs and 12 for the rear sway bar. Tousley Ford has great prices for FTE members if you have to go new. CT Performance can get you dialed on everything to make the combination work together... Cary is the greatest!
Old 08-06-2014, 04:17 PM
$80 for all 4!??
Old 08-06-2014, 06:05 PM
Thumbs up
Like I said, it was their 1/2 price weekend! I was amazed that they had a truck that had everything I was looking for that hadn't been picked over. Took me about 5 hours to wrestle it all out with hand tools; I took it all and ran!
Old 08-06-2014, 08:42 PM
Wyomingowen Wyomingowen is offline
Wyomingowen is starting off with a positive reputation.
I haven't had the coin to do it yet but I want to confirm what walt says, reach out to Cary at CT performance, he's got the whole thing dialed.
Also, 00-03 x has no sway bar at all!!!! what was the blue oval thinking!!! again, cary will cover that issue as well.
Somewhere in this forum it discusses how the blue oval due to marketing softened the suspension as compared to the F250 and lowered it so it would fit in most peoples garages, a serious dilemma for the weight you're driving, hence floaty, drifty = scary
Old 08-06-2014, 11:36 PM
rock2610d's Avatar
rock2610d rock2610d is offline
rock2610d has a good reputation on FTE.rock2610d has a good reputation on FTE.
Your on the right track. My local ford dealer quoted me $126 each for new v codes. At that price I cannot pass that up. So try the dealers first. The rears were quoted at $256 each. A tad pricy for me, as there is a local truck salvage yard that has 10 or 15 super duties. Rear sets are $75. So check local yards. If you are lucky you could pick up a rear away bar too.
Old 08-07-2014, 12:01 AM
http://www.ford-trucks.com/forums/11...l#post11346356
Here's the thread that covers it all, I can't wait to do this as the Mrs recently said sell the minivan I like the ex (we've owned it for 10 months now)
so my sig will say 97 f350 psd and 01 ex psd (no more sienna...yahoo)
Best 2" lift for a 4x4 Ex? Scott51 Excursion - King of SUVs 16 09-01-2016 08:04 PM
diesel springs rangernut09011980 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 03-31-2015 01:47 PM
Springs andym Excursion - King of SUVs 23 12-03-2014 09:06 PM
Spring question trucktech Excursion - King of SUVs 8 07-11-2012 11:52 AM
Oh no, more v/b code questions that need answers bigwhitetruck01 Excursion - King of SUVs 27 05-27-2012 04:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
