V/b spring confusion
Old 08-07-2014, 04:31 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by Wyomingowen
https://www.ford-trucks.com/forums/1...l#post11346356
Here's the thread that covers it all,
I beg to differ. If you go to the tech folder sticky thread, that's the thread that covers it all.
Click on the tech folder thread and scroll down to Suspension, Steering, Axles, Hubs, Driveline, etc and you'll have the links to all the suspension threads you could want, covering all the options other users have chosen.
Stewart
Old 08-07-2014, 11:34 AM
Wyomingowen's Avatar
Wyomingowen
Wyomingowen is offline
4wd High
what mods have you made?
Stewart
Thanks Stewart. Please let me clarify as CT's run down (authored by one of his customers, as I don't want to be seen as speaking for Cary either) I can only say Cary gives prompt response to inquiries and pricing seems very fair.
So Stewart what suspension mods have you made? Thanks again
Old 08-07-2014, 12:41 PM
Stewart_H's Avatar
Stewart_H
Rich (White Buffalo) is the man who wrote up that thread. It's in the tech folder too, in the "compilation" link.
There was an undercurrent of humor in my post above because the threads in the tech folder covers more than just one way to skin the proverbial cat called Excursion Wander and that tech folder thread really covers it all.
Cary was instrumental in helping all Excursion owners when he decided to go into business and sell a "one-stop kit" that fixed the Excursion Wander. From all accounts, he provides excellent customer service.
It's listed in my sig.
Stewart
Old 08-07-2014, 02:40 PM
wrxin's Avatar
wrxin
wrxin is offline
I got all 4 used F350 springs and the taller F350 blocks for $200.00. I was able to verify that they are V/S codes.
Old 08-07-2014, 04:37 PM
Curjo's Avatar
Curjo
Curjo is offline
Both the guys want $300 for the springs and blocks. He's pulling them off though. Does this seem alright?
Old 08-07-2014, 04:49 PM
holeshotwalt's Avatar
holeshotwalt
holeshotwalt is offline
Thumbs up
The price seems OK, but the problem is you really have no idea what you're getting... I would not buy something that you may have to buy again- after you've gone to the hassle of installing them to find out they're not what you want!
The V's and B's were spec'd because they lift but still ride well.
Buy well and buy once!
Old 08-07-2014, 05:05 PM
holeshotwalt
Thumbs up
The other thing is, mileage of those springs. If they're ancient, or have hard miles (heavy loads, towing, plowing); they're not what they once were in regards to rating.
IMHO,There are a lot of these trucks out there and most folks who want to sell will go to the trouble of giving you the code off the door so you know what you're buying. Good luck!
Old 08-07-2014, 05:49 PM
wrxin's Avatar
wrxin
wrxin is offline
Curjo,
If you're going to buy mystery springs, I'd first review all the possible springs codes for the donor truck. For example, the front could be V or X. X was part of a snow plow package. I don't think X code raises the front any more than a V but presumably it will ride a bit harder. There are more possibilities for the rear.
You can always buy springs, install them, see how your X sits and rides, or you can follow what some has done to get a predictable outcome.
I'm a good example. I used "modded" S rear springs (very similar to Bs) and then added the F350 blocks. I knew the front would be too low with just the V because of the F350 blocks, so I added 2" lift shackles. That wasn't enough so I added Skyjacker add-a-leafs to the front. The result was a perfectly level X. I didn't want the factory "lean" and I knew I wanted 35" tires on stock rims.
After all that, I had to get hub centric wheel spacers because the front tires were robbing on the leaf springs near steering lock in either direction. I like the look with the spacers too.
So its all up to you and I don't blame you for looking for the least expensive option.
Old 08-07-2014, 06:16 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
Just to clarify, the S code is a B spring. I have no idea why Ford called it different but S and B share the same part number.
Old 08-07-2014, 06:30 PM
wrxin's Avatar
wrxin
wrxin is offline
Yep. I didn't want to confuse things more. If the OP is able to send you a VIN number and accept your gracious offer for help, we might get somewhere.
Old 08-07-2014, 06:34 PM
RobRoss's Avatar
RobRoss
RobRoss is offline
Hope so, I can also figure from part numbers if he gets that far (or anyone else).
Old 08-07-2014, 09:28 PM
Curjo's Avatar
Curjo
Curjo is offline
I've asked the sellers for the information again and hopefully they get back to me with it or I may just have to keep looking. I'm going to have to call some junkyards around and see if anyone has them.
  #28
Old 08-07-2014, 10:49 PM
wrxin's Avatar
wrxin
wrxin is offline
It's very rare to find a super duty at a junk yard. Where I live, in colorado, dismantlerers get the super duties and part them out and charge $500 for a set of leaf springs. I have seen 1 super duty in a junk yard. It was 2-wheel drive and picked apart the day it arrived. It took me 2 years to find the set I got from a semi truck dealership that was parting out an F350. Honestly, good luck!
  #29
Old 08-08-2014, 12:59 PM
Curjo's Avatar
Curjo
Curjo is offline
Ok so I can't post a pic from my phone but the front spring numbers are: F81Z-5B311-AA.
  #30
Old 08-08-2014, 01:03 PM
wrxin's Avatar
wrxin
wrxin is offline
Google says that's a shackle not a spring.
Quick Reply: V/b spring confusion
