V/b spring confusion
Click on the tech folder thread and scroll down to Suspension, Steering, Axles, Hubs, Driveline, etc and you'll have the links to all the suspension threads you could want, covering all the options other users have chosen.
Stewart
what mods have you made?
I beg to differ. If you go to the tech folder sticky thread, that's the thread that covers it all.
Stewart
Stewart
So Stewart what suspension mods have you made? Thanks again
There was an undercurrent of humor in my post above because the threads in the tech folder covers more than just one way to skin the proverbial cat called Excursion Wander and that tech folder thread really covers it all.
I can only say Cary gives prompt response to inquiries and pricing seems very fair.
Stewart
The price seems OK, but the problem is you really have no idea what you're getting... I would not buy something that you may have to buy again- after you've gone to the hassle of installing them to find out they're not what you want!
The V's and B's were spec'd because they lift but still ride well.
Buy well and buy once!
The other thing is, mileage of those springs. If they're ancient, or have hard miles (heavy loads, towing, plowing); they're not what they once were in regards to rating.
IMHO,There are a lot of these trucks out there and most folks who want to sell will go to the trouble of giving you the code off the door so you know what you're buying. Good luck!
Curjo,
If you're going to buy mystery springs, I'd first review all the possible springs codes for the donor truck. For example, the front could be V or X. X was part of a snow plow package. I don't think X code raises the front any more than a V but presumably it will ride a bit harder. There are more possibilities for the rear.
You can always buy springs, install them, see how your X sits and rides, or you can follow what some has done to get a predictable outcome.
I'm a good example. I used "modded" S rear springs (very similar to Bs) and then added the F350 blocks. I knew the front would be too low with just the V because of the F350 blocks, so I added 2" lift shackles. That wasn't enough so I added Skyjacker add-a-leafs to the front. The result was a perfectly level X. I didn't want the factory "lean" and I knew I wanted 35" tires on stock rims.
After all that, I had to get hub centric wheel spacers because the front tires were robbing on the leaf springs near steering lock in either direction. I like the look with the spacers too.
So its all up to you and I don't blame you for looking for the least expensive option.
It's very rare to find a super duty at a junk yard. Where I live, in colorado, dismantlerers get the super duties and part them out and charge $500 for a set of leaf springs. I have seen 1 super duty in a junk yard. It was 2-wheel drive and picked apart the day it arrived. It took me 2 years to find the set I got from a semi truck dealership that was parting out an F350. Honestly, good luck!
