V/b spring confusion - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 08-09-2014, 08:16 AM
RobRoss's Avatar
RobRoss RobRoss is offline
RobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud ofRobRoss has much to be proud of
Quote:
Originally Posted by Curjo View Post
So there would be no way to modify them then? The guy has everything else that I need and it's kinda a package deal. I'll trust you guys if you think I should call it off though. I was supposed to make the deal tomorrow after work.
There's plenty to work with there, it's possible someone modified the pack to what you see now. It's up to you, this project may be more trial and error since we don't know what it is but it's really up to you. For sure the overload spring needs to come off and then another leaf or two Depending on what you're trying to get to (height wise) and if you want to run blocks or not.
  #47
Old 08-09-2014, 08:27 AM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Those springs look like C code. If you don't want them then I'll take them..
  #48
Old 08-09-2014, 09:08 AM
RobRoss's Avatar
Quote:
I don't think those are C codes. C, S, V codes all have a helper at the bottom, Excursion is the only one that doesn't. It's possible it is/was a super duty spring pack with the lower aux removed. Hard to say what it really is at this time...
  #49
Old 08-09-2014, 10:38 AM
Pitcrw6's Avatar
Quote:
V codes are a front spring and never seen them with a helper spring from the factory. Did you mean B code?
  #50
Old 08-09-2014, 11:49 AM
Curjo Curjo is offline
Curjo is starting off with a positive reputation.
I'm gonna make them work somehow. Probably take out a leaf or two and definitely the one off the top.
  #51
Old 08-09-2014, 02:03 PM
Pitcrw6's Avatar
I just looked at my OEM B code springs on my 02 SRW F350 and I have 4 leafs, 1 helper and 1 overload spring. Mine have never been removed from my truck. In the pics on page 1 there are 10 leafs and 1 overload spring which is why I said those must be C codes that where on a DRW F350 or higher.
  #52
Old 08-09-2014, 04:56 PM
RobRoss's Avatar
Yes, sorry, I did mean B code. Thanks for catching it!
  #53
Old 08-10-2014, 02:20 PM
Anyone have an idea on the best way to modify the rears?
  #54
Old 08-11-2014, 01:51 PM
So looks like I have f-450 springs from my Internet research. They were the only springs that I could find that had 11 leaves in the pack. Must have been an option for heavy duty towing on a f350. Should I try these as is or take a few leaves out? Also if I leave as is should I add a 2" shackle to the fronts? And last but not least, did you change out the bushings in the springs when you swapped them?
  #55
Old 08-11-2014, 07:14 PM
Pitcrw6's Avatar
If you want a stiff ride then leave them as is. Otherwise you can take out a couple leafs and go from there. I would think you would have to add some shackles to the front if you left the rears alone.
  #56
Old 08-21-2014, 08:45 PM
I've looked all over for a rear sway bar install write up but I can't find one. Pretty sure I'm going to try and tackle everything this weekend and am pretty confident about the spring swap but not sure about the sway bar install since I'm not replacing one, I'm adding it.
  #57
Old 08-22-2014, 12:25 PM
holeshotwalt's Avatar
holeshotwalt holeshotwalt is offline
Spooled Up, Throttle Down
holeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to beholdholeshotwalt is a splendid one to behold
Thumbs up sway bar install
If you just set the bar over the driveshaft/ differential, you'll see where the 'U' brackets go in the grooves that are cast into the diff housing. Then the end rods (that go up to the frame) will land near the holes in the frame to bolt to. Easiest install ever!
  #58
Old 08-22-2014, 08:02 PM
Thumbs up
I just remembered- the passenger side rear shock mount has a plate on the front side that needs to be trimmed down so the sway bar will clear. You'll see when you have things sitting there. Good Luck!
Best 2" lift for a 4x4 Ex? Scott51 Excursion - King of SUVs 16 09-01-2016 07:04 PM
diesel springs rangernut09011980 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 03-31-2015 12:47 PM
Springs andym Excursion - King of SUVs 23 12-03-2014 08:06 PM
Spring question trucktech Excursion - King of SUVs 8 07-11-2012 10:52 AM
Oh no, more v/b code questions that need answers bigwhitetruck01 Excursion - King of SUVs 27 05-27-2012 03:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
