Run Engine After Removal? - Ford Truck Enthusiasts Forums
Old 08-05-2014, 11:34 AM
73fan's Avatar
73fan 73fan is offline
73fan has a good reputation on FTE.73fan has a good reputation on FTE.
Hey fellows I just took the 7.3L engine out of the old '97 that was smashed up a few years ago, and was wondering how difficult it would be to fire it up. I realize it's all computer controlled and it would require the PCM to run, but anyone have info on what I need to connect to what on the PCM in order for it to run? I'm not really trying to make it fully operable at the moment, but would like to hear it run again. I wouldn't need throttle or glow plug control and such... Any input appreciated.
Sent from Nexus 4. IB AutoGroup
Old 08-05-2014, 11:34 PM
quesey's Avatar
quesey quesey is offline
quesey is gaining momentum as a positive member of FTE.
think you have to have all the harness go pedal an pcm an idm.
basically just like it was in the truck.
http://www.ford-trucks.com/forums/11...se-stands.html
I'm going to build 1 one of these days
Old 08-07-2014, 12:31 AM
73fan's Avatar
That would be great!
EGR delete PCM reflash Check Engine light, any fix? terrymargate 1999 to 2016 Super Duty 2 03-26-2016 08:03 PM
1995 f350 5.8 starts no PCM and no start with PCM? ifiteverruns 1987 - 1996 F150 & Larger F-Series Trucks 22 03-30-2015 12:54 PM
'96 F350 PCM problem? chintonmd 1994.5 - 1997 7.3L Power Stroke Diesel 35 09-21-2012 12:26 AM
what would cause a code PO605? 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 6 11-04-2011 07:31 PM
PCM id codes zempman Computer Chips & Tuners 5 09-12-2005 03:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
