fuel reset switch - Ford Truck Enthusiasts Forums
fuel reset switch
Old 08-05-2014, 10:30 AM
Glenn Blackwell Glenn Blackwell is offline
Glenn Blackwell is starting off with a positive reputation.
fuel reset switch
When I slam the rear hatch shut, the fuel reset light shows. 95 Explorer.
Old 08-05-2014, 12:27 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Does it actually trip the inertia switch, or just the light comes on? What does it take to get the light to go out? Or maybe you were just making a statement and not actually looking for help?
-Rod
Old 08-05-2014, 12:34 PM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Dont slam the door.
Old 08-05-2014, 07:05 PM
Quote:
-Rod
Inertia Switch does trips (1) fuel reset light shows. (2) engine will not start. Light goes out: when under the dash switch is reset by hand.
Old 08-05-2014, 09:41 PM
shorod's Avatar
If you don't feel that you are slamming the rear hatch abnormally hard, then you might have a structural issue that is causing excess shock to make it to the inertia switch. I'm not positive how the switch was constructed in the 1995 model year, but Ford inertia switches in the late '80's consisted of a switch and trigger mechanism installed above a conical magnet with a steel ball bearing. There really wasn't much that could wear out in one of those to cause it to trigger prematurely unless the trigger mechanism broke.
If you don't believe you are being too rough and there are no signs of structural damage on the truck (broken welds or frame members) then you probably need to replace the inertia switch.
-Rod
Old 08-06-2014, 05:15 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I'd replace the switch. At least take it apart and inspect it.
Is A Battery Reset Required After Installing New Injectors? EViS 2004 - 2008 F150 1 10-11-2015 10:03 AM
cani do a factory reset? JosephDunivan 1999 to 2016 Super Duty 4 08-22-2015 05:57 AM
resetting oil change reminder georgeda Escape & Escape Hybrid 8 05-23-2015 07:15 AM
fuel problem rwmurr18 Air Intakes, Air Filters & Ram Air 0 04-16-2015 12:01 AM
fuel filter reset Gary O 6.7L Power Stroke Diesel 8 03-14-2014 09:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
