idle issues - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
idle issues
Old 08-05-2014, 11:18 AM
pbarw pbarw is offline
pbarw is starting off with a positive reputation.
idle issues
95 302 either idles high or barely idles until warm. Once you get it running it will stay running. Any ideas? TPS?
Old 08-05-2014, 11:30 AM
jasoncarpenter1's Avatar
jasoncarpenter1 jasoncarpenter1 is offline
jasoncarpenter1 is gaining momentum as a positive member of FTE.
Search how to test TPS. You can test before you buy one. Also IAC might be bad. You can test also. BTW did you check for codes???
Old 08-05-2014, 11:35 AM
The check engine light never came on so I assumed no codes. Thanks I will look that up.
Old 08-05-2014, 02:59 PM
Go here its a lot more active than the bronco section. If search or read the older threads you will find more info on your issues. BTW you probably have stored codes. No way to tell unless you scan it.
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
91 5.8 very high idle Plowboy34 1987 - 1996 F150 & Larger F-Series Trucks 3 12-07-2015 10:39 AM
7.3 Noisy at idle wtroger Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 08-11-2015 07:32 PM
Rough idle cold Fummins 1987 - 1996 F150 & Larger F-Series Trucks 5 02-24-2015 04:51 PM
fast idle, up and down gbrewer 1987 - 1996 F150 & Larger F-Series Trucks 7 01-27-2015 07:40 PM
f350 idle/fuel problem godtar02 1987 - 1996 F150 & Larger F-Series Trucks 14 12-29-2014 04:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
