door linkage - Ford Truck Enthusiasts Forums
door linkage
Old 08-05-2014, 09:17 AM
Jarryd's Avatar
Jarryd Jarryd is offline
Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.
door linkage
94 single cab f150.
The door linkage keeps locking up on me and I can't pull the door handle. The handle moves a little but won't activate the latch. I had this happen once before and broke the handle off. I replaced the handle and it worked for a couple months and it's frozen again.
I read something about the older linkage being a rod style rather than a cable and I didn't know if these parts could be purchased new rather than digging around through old possibly worn out parts.
Any advice?
Old 08-12-2014, 03:31 PM
Jarryd's Avatar
Bumping this. I had freed it up enough to use but the handle snapped off again. Something is seriously wrong and I don't know what to fix our replace.
Old 08-12-2014, 04:34 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
It's not clear what you're asking. Are the parts available for the older style without a cable? Probably but they won't fit your truck. You have cable operated latches.
Old 08-12-2014, 05:15 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
Actually bashby if he were to buy the latches, and all the rods he would be able to swap it over to it. If I were him I would go to the junkyard and buy the whole door from an 80-91 truck and take the guts from it and put it in his doors.
Trav
Old 08-18-2014, 06:33 PM
Jarryd's Avatar
If I grab a whole door off a truck, it's $44 at the junk yard but if I take the time to disassemble there, it will be $10. I figure I can just rip the door panel off and use a sawzall to cut out the section of door I need and unbolt the good stuff.
Old 08-18-2014, 09:47 PM
SteelHorse4x4's Avatar
SteelHorse4x4 SteelHorse4x4 is offline
SteelHorse4x4 is starting off with a positive reputation.
I would buy new latches ( or very GOOD used ones) and NEW cables. The cables stretch over time, and the latches wear also, causing you to have to pull farther and farther until the handle hits its stop which breaks before the cable.
Old 08-18-2014, 09:49 PM
Jarryd's Avatar
Quote:
I'm going with the rod style that doesn't stretch. I'll make it work.
Old 08-19-2014, 11:48 AM
Quote:
Please only do that if the door is dented to bad to be repaired or used or if it is rusted beyond repair. You don't know how many people go looking for nice straight doors in my area to find somebody decided to take a sawzall to the door to get something simple like a door latch.
To steel horse if he goes to the rod style instead of the cable style he would be replacing it with a much better designed deal.
Trav
Old 08-29-2014, 09:22 AM
Jarryd's Avatar
That looks like it would work but the link they provided is for 97-04. Will they work on my truck?
I may still be better off doing a rod conversion.
Door handle problem Hasbro61 Excursion - King of SUVs 2 12-11-2016 01:49 PM
Aftermarket door handles grasfarmr73 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-22-2015 09:41 AM
94 f150 door linkage Jarryd 1987 - 1996 F150 & Larger F-Series Trucks 4 06-15-2014 12:12 AM
broken door handle Leo_T 1968-2013 Full Size Vans 12 09-28-2013 12:25 AM
how do I get the outside door handles off? drewduncan15 1973 - 1979 F-100 & Larger F-Series Trucks 15 06-11-2012 05:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
