A couple questions about replacing an E4OD with a C6 - Ford Truck Enthusiasts Forums
Old 08-05-2014, 06:06 AM
86pullerf350's Avatar
86pullerf350 86pullerf350 is offline
86pullerf350 is starting off with a positive reputation.
I put this up in the transmission and clutch section last week with not one reply so I guess I'll ask here, hopefully with better luck.
I just got a 94 f250 4x4 with 7.3 non turbo. The po had told me that he used it to plow his dirt driveway in the winter and grade it in the spring with the plow. He beat the trans pretty good but the engine still runs excellent. I just replaced the glow plugs with Motorcraft ZD-9 glow plugs.
I have a C6 from an 1986 f250 4x4 with about 2000 miles on it that i would like to put in place of the e4od. The c6 came out of a parts truck I have so I have the wiring harness for it. I found on here (I think) somewhere that someone has done it but cant find it again. I know the crossmember needs to be moved forward, c6 needs a vacuum line to it, and obviously the harness needs to be changed.
What else do I have to look for? How would I rewire the two harnesses together to make it work?
Any suggestions will help.
Thanks
Old 08-05-2014, 08:35 AM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
Off what engine was the C6 taken? If it's off a gas engine, it won't fit (different bellhousing patterns), and I'm not sure if there are bellhousing differences among the diesels.
Regardless, you're going to have all sorts of issues, as the E4OD is totally electronically controlled, and the C6 is totally vacuum controlled. The computer on your '94 isn't going to like it.
It would be a lot of aggravation for a lesser tranny.
Jason
Old 08-05-2014, 01:02 PM
jroehl, It came off an 86 6.9l diesel. I was just throwing the idea around about the swap but will probably end up replacing with the correct tranny.
Need wiring harness for 1993 f250 5.8 JClark785 1987 - 1996 F150 & Larger F-Series Trucks 2 11-13-2016 08:52 PM
Will trans from 88 4x4 Diesel engine go into 91 4x4 Gas Wolfy77 1987 - 1996 F150 & Larger F-Series Trucks 3 09-29-2016 11:43 AM
Van Swap idiguy90 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-19-2015 01:10 PM
Questions about replacing an e4od with c6. 86pullerf350 Clutch, Transmission, Differential, Axle & Transfer Case 0 08-01-2014 11:49 PM
1992-1995 E4OD harness difference ssn2197 Clutch, Transmission, Differential, Axle & Transfer Case 2 08-04-2011 12:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
