Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc..
Old 08-10-2014, 10:36 AM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
Originally Posted by trumph
Yep subscribing really interested on the jag conversion
Lots of jag pics in my first build which is still in progress, see the link in my signature.
May not be as may pics in this thread, depends on what people want me to post.
Old 08-10-2014, 04:40 PM
drptop70ss's Avatar
drptop70ss
Nose is apart and off the truck, found some pretty interesting hardware here and there..looks like as long as it would work it was used. Almost nothing saved, all cut off and junked. This was midway through.
Jag rolled back under to mark the frame for clean up, I am still amazed how easily the jag fits these frames.
Old 08-11-2014, 02:25 PM
drptop70ss's Avatar
drptop70ss
Jag is in! Set in place same as my first build (see that build for detailed measurement pics), welded on the outside edges, inside frame heated and bent down meet the jag crossmember.
fully welded in both sides
sanity check, frame level and jag crossmember level.
welded up front
This area I make a filler piece and weld up but not until the frame is upside down.
Next is the front sway bar mounts. A neat thing about this is one of the sway bar mounting bolts lines up with this rivet so it makes the install easy.
Rivet out, jag sway bar pad bolted up to the frame. Mark the 2nd hole and drill it in the frame.
Front crossmember welded to the frame and a nut welded to the crossmember. Rear nut I weld to a piece of 1/8" plate which is welded to the frame, there is a lot of stress on the bar so this helps stiffen up the area.
Next will be boxing the front rails.
The following users liked this post:
Old 08-11-2014, 03:18 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Dave,
Love your pics/tutorial. For some of us who aren't as familiar with the Jag set up - It comes with a stock sway bar & that's what you are installing? Or is it an after market one? I love how you say there wasn't as much rust on this one..... Looks plenty rusty to me.
Ben in Austin
1950 F1
Old 08-11-2014, 04:51 PM
drptop70ss's Avatar
drptop70ss
Originally Posted by ben73058
Hey Dave,
Ben in Austin
1950 F1
Hey Ben,
This uses the factory XJ6 front sway bar that comes with the IFS. Not huge by todays standards but will work fine for the truck. I believe the aftermarket has larger diameter bars for the jag if someone wanted one.
This truck is unbelievely solid and rot free..lot of rust? It is a Texas truck!
Old 08-11-2014, 06:24 PM
trumph's Avatar
trumph
trumph is offline
Good stuff dave looked at your other build and that is awsome as well watching and gathering infomation
Thanks
Old 08-11-2014, 07:40 PM
LosFeliz's Avatar
LosFeliz
LosFeliz is offline
Such informative thread. How do I suscribe as the others? Will be looking to read about your first build as well.
Old 08-11-2014, 08:34 PM
BradsF1's Avatar
BradsF1
BradsF1 is offline
Subscribed can't wait to watch the build.
Old 08-11-2014, 08:37 PM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
Welcome to FTE!
Because you have posted to this thread you are subscribed.
Old 08-12-2014, 08:06 AM
AXracer's Avatar
AXracer
AXracer is offline
As said when you post to a thread you are automatically subscribed, but if you want to subscribe to a thread without posting:
1 Log in.
2. See the blue band just above the first post on a page, click on thread tools.
3. Click on subscribe to this thread.
4. You are subscribed!
Old 08-12-2014, 05:37 PM
LosFeliz's Avatar
LosFeliz
LosFeliz is offline
Great! thank you for the help. We're also planning a resto with our bad girl, with a 5.0 HO swap. Currently collecting and absorbing as much information as possible first. This is why your thread is worth gold as with all the info on this site.
Old 08-12-2014, 07:41 PM
drptop70ss's Avatar
drptop70ss
Hey I hope I can help out some even if we may be using different parts. A lot of the basics are the same.
So this morning it was time to box the front rails. Once again I went low buck and made the plates from some frame cuts I had around, I think these were 55 packard. Heavy stuff, 1/8" or better, and free
Welded in
Doors on this truck were stuck shut, latches are stuck. Popped the drivers door open from the jam area and found a few things inside! Time for the shop vac.
All cleaned up, floors look good, only saw some pinholes on the passenger side. This is like a new cab compared to my other truck.
Original tank is there but I assume it is junk. No way am I going to attempt using it with fuel injection.
  #28
Old 08-12-2014, 08:30 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Dave,
I find it interesting that you installed an entirely new front end before you even opened the cab doors! What was the black spittoon looking thing down in front of the seat?
Ben in Austin
1950 F1
  #29
Old 08-13-2014, 05:51 AM
drptop70ss's Avatar
drptop70ss
Hey Dave,
Ben in Austin
1950 F1
Hey Ben,
It is an oil filter cannister similar to what the flathead used. I found some misc engine parts in the cab so looks like the original engine was torn down at some time.
Now that you mentioned it that is pretty funny how I prioritize my work! I need the chassis in paint before winter so the truck will be ready to drive in the spring, so I want to get as much chassis fab work done as possible now.
  #30
Old 08-13-2014, 06:06 PM
drptop70ss's Avatar
drptop70ss
More interesting stuff..found the speedo in the toolbox, looks like a chevy truck unit in there?
Looks like Farmer Bob really wanted a radio in his truck, now this is some quality work! The chisel used to make the opening must have been dull.
Anyone know what this radio is from?
Quick Reply: Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc..
