Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc..
  #151
Old 02-17-2015, 09:22 AM
r_reed's Avatar
r_reed
r_reed is offline
just read the whole thread. you do amazing fab work. you also knock it out quickly. will be watching for the rest as winter finally leaves.
  #152
Old 02-17-2015, 09:50 AM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
Thanks! Are you up around the Albany area? Not too far north of me so you must be sick of winter by now as well!
  #153
Old 02-23-2015, 09:12 PM
drptop70ss's Avatar
drptop70ss
Well the weather actually wasnt bad yesterday and got above freezing! Small miracle but I will take it. Trudged through the snow and dug out some scrap 1 1/4" square tubing and whipped up a mount for the dakota seat. It will mount to the factory seat mounting holes.
Also got my gauges today, one less item to get.
Seat goes back in tomorrow for final position check, then back to redo the steering column.
  #154
Old 02-24-2015, 12:03 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Looks good!
I'm not meaning to sound critical of your work, but I'm just learning to weld. It looks like the square tubing you welded is rusty. I thought the metal had to be bare for the weld to work properly. Did I misunderstand something?
  #155
Old 02-24-2015, 07:22 AM
schoo's Avatar
schoo
schoo is offline
Dave did you add a reinforcement to the floor at those points, got pic?
Thanks for the info
  #156
Old 02-24-2015, 07:49 AM
drptop70ss's Avatar
drptop70ss
Originally Posted by Jolly Roger Joe
Looks good!
Yep, have to have clean metal to weld or you get plenty of spatter and bad penetration. All the joints were ground clean to shiny metal before welding, then the whole thing will be cleaned up completely before paint. This is the mockup phase so it all get build before getting blown apart for paint.
Even new steel has to have the ends ground clean to remove the mill scale, dont just go buy some tubing and weld it without cleaning it up.
Thanks for the info
No extra floor reinforcement, the factory seat mounting points go into the floor supports under the cab.
  #157
Old 02-24-2015, 04:39 PM
drptop70ss's Avatar
drptop70ss
Finished up the seat mount today, worked great. If you are considering a dakota seat here is some info. If anyone wants dimensions let me know and I will get them.
Dakota split bench seat is really two buckets seats with the console mounted in the middle. There is no frame holding them together, they are bolted together but not rigidly so the setup is pretty flimsy when out of the truck.
There are 4 rear mounting points for the seats and seat belts. I used 1/2" bolts that go through the seat, through the 1 1/4" tube, and thread into nuts that are welded on the bottom of the tube. Sorry for the blurry pic, this is one side.
Front of the seat bolts in with four bolts, I drilled and tapped (4) 3/8" x 16 holes into the 1 1/4" tubing.
Square tube was used for feet and then 1/8" steel plate for the pads which bolt to the factory bench seat locations.
The front feet are longer than the rear to put a little angle in the seat. I cant remember the numbers but I can get dimensions if anyone wants them.
The sides of the mount will get covered with carpet when I do the interior, I am going to keep the front open so I can store stuff under the seat if needed.
  #158
Old 02-24-2015, 04:47 PM
schoo's Avatar
schoo
schoo is offline
cool dave thanks
  #159
Old 02-25-2015, 02:33 PM
drptop70ss's Avatar
drptop70ss
Modified my steering column mount and switched to a tilt wheel that is now centered in between the gauge pods. I never did understand why it wasnt that way originally.
  #160
Old 03-01-2015, 10:30 PM
drptop70ss's Avatar
drptop70ss
Dash work starts..
Snowed all day today and still going but by 3pm I was so stir crazy stuck in the house I had to get out and do something.
My dash had a hole cut in it for the radio that looked like it was cut with an axe, total butchery. had to fill the hole to start over.
Filled the speaker hole as well, not going to mount a speaker there.
More tomorrow, I work outside until I cant feel my feet!
  #161
Old 03-03-2015, 01:13 PM
drptop70ss's Avatar
drptop70ss
Got some more dash work done.
Welded in rings to make the gauge holes smaller for the new speedo and tach and that left enough room for one of the smaller gauges.
Also filled all the switch holes and ignition switch hole since they will not be needed, modified the far left hole for a GM headlight switch.
Test fit
Since I am not putting a speaker in the dash and am moving the stereo I made up a plate to replace the speaker grille for the rest of the gauges.
Cut the dash opening
Test fit
Test fit with the trim. Nothing is bolted in, just set in place for the picture. I have studs welded on the back of the gauge plate so it bolts in the same place as the speaker grille. Just have to weld a lip on the bottom of the plate, forgot to leave enough metal at the bottom to roll over under the dash.
  #162
Old 03-03-2015, 06:19 PM
drptop70ss's Avatar
drptop70ss
After looking at the pics I didnt like the bottom of the gauge plate covering the lower dash, so I cut off the bottom inch or so and rolled the bottom so it is now basically the same size as a speaker grille. Now the very lower part of the dash is visible so I can keep the two tone style paint on the dash like factory. Didnt have the camera with me, just ran out to get it done before it got too late today. When inspiration hits gotta get it done! Pics another day
  #163
Old 03-03-2015, 06:49 PM
jgp1952's Avatar
jgp1952
jgp1952 is offline
Hi, thank you!
I make my own fuel lines so I will have a factory style "can" fuel filter in the supply line. I will also be replacing the TBI fuel pump with a higher pressure unit for my LT1s which run at 45psi.
Hope this helps!
Hi Do you mind sharing what pump you used for this tank? I am thinking of using this tank in my project and I'll need to get a similar pump with higher pressure. I'm assuming it will be a combo sender\pump\return? The info would be very appreciated.
Thanks.
  #164
Old 03-03-2015, 07:24 PM
drptop70ss's Avatar
drptop70ss
Thanks.
Sending unit is for the 1995 van, so it has the feed, return, vent, and larger vent that goes to the filler tube ( I run a sealed system with a non vented cap and charcoal canister to work with the EVAP system).
The pump you want to use is Airtex PN 3270 which is for a 1995 chevy caprice with the V8 (LT1). It puts out 80-90 psi and is regulated down to 45 psi which is needed for the MPFI, the TBI pump only puts out around 15 psi.
Ignore that external fuel pump, that is a secondary pump I need because of the supercharger. Normally the in tank pump is all that is needed.
The pump is a direct swap other than the pump outlet size is 5/16" vs 3/8" on the TBI, so you have to lube the 5/16" hose to get it to slide over the 3/8" stub on the sending unit...or clamp down the 3/8" hose enough to seal to the 5/16" stub on the pump.
Rock auto has the pump for around $35.
  #165
Old 03-04-2015, 01:39 PM
jgp1952's Avatar
jgp1952
jgp1952 is offline
Thanks! I just ordered the the tank kit with straps, sending unit assembly, and tank. I also got the pump you referecned and bought a EFI regulator and guage. For my 4.6 3v I need a contant 40PSI.
I'm following your progress, thanks for all the posting you do. Very helpfull.
Gary
Quick Reply: Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc..
