Floor board clean-up - Ford Truck Enthusiasts Forums
Old 08-04-2014, 08:06 PM
SteelHorse4x4's Avatar
SteelHorse4x4 SteelHorse4x4 is offline
SteelHorse4x4 is starting off with a positive reputation.
Hey guys, got an idea, and I would like your opinions. The factory tar pad or whatever its called was severely dried out and crumbling on the floors of my 94. I scraped it all up and thankfully everything underneath is in good shape. I'm cleaning it all up etc. etc. Anyway, instead of paying ridiculous prices for new sound deadening pads there, I was contemplating using pieces of EPDM torch-down roofing and possibly heating it up and sticking it to the floors in its place, any thoughts?
Old 08-04-2014, 08:10 PM
Chrisrehpot's Avatar
Chrisrehpot Chrisrehpot is offline
Chrisrehpot is gaining momentum as a positive member of FTE.
Why not use some bed liner? When I tore my flooring out in my 94 F150 and found $100. But I was thinking on doing a bed liner in it before I gave it to my brother.
Old 08-04-2014, 08:52 PM
Truck Guy99's Avatar
Truck Guy99 Truck Guy99 is offline
Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.
Fat mat is a cheap alternative to overpriced insulation. Just hear it up lightly with a heat gun or hairdryer. It makes it soft and bendable without tearing and it's great for getting into the contours of the cab. Bed liner is good but then your interior stinks for a while until it's totally cured
Old 08-04-2014, 09:10 PM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
I used peel n seal in my truck, on the floor, back wall, and roof. Pretty cheap at Lowe's or Home Depot.
Old 08-04-2014, 09:15 PM
Bedliner is a possibility, but not my first choice. I use the peel and seal stuff all the time installing doors and windows. Its good stuff, but considerably thinner than the EPDM rubber left over from one of my flat roof jobs. This stuff, if you've never been around it is just under a 1/4 inch and is very dense and durable.
Old 08-04-2014, 09:18 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Ditto. Peal and Seal is 6" x 25' for about $16
Old 08-05-2014, 07:21 AM
Quote:
Well, if you have free leftovers, I think you've found your answer.
NEED BRAKES HELP!! 78BluePig 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-25-2016 10:57 PM
1994 F150 - Cab Leak Demonhawk 1987 - 1996 F150 & Larger F-Series Trucks 18 11-13-2015 09:58 PM
No Brakes after Caliper/Brake pad Change Havas E 2004 - 2008 F150 18 09-23-2015 03:09 PM
Help! New rear brakes, peddle goes to the floor intermittent? radmacks Excursion - King of SUVs 6 03-23-2015 08:25 AM
Brake Fluid Carpet Cleaning? JWA Brakes, Steering, Suspension, Tires, & Wheels 2 05-26-2014 11:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
