Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 08-04-2014, 06:54 PM
49fordv8f4's Avatar
49fordv8f4 49fordv8f4 is offline
49fordv8f4 is starting off with a positive reputation.
New Member
I've been lurking here for a while so, I thought I would join in. I am a self employed Machine Shop owner/operator in north central Arkansas. I have been working on a '49 F4 build for a while to eventually use as my shop truck. My truck was a grain truck from Kansas with about 64000 miles on the odometer. The flathead v8 was seized from water in one cylinder. My original plan was to build a Mercury flathead to replace it but, I've changed course. I installed a '84 Mercedes 300 turbo diesel in its place. I have it mated to the original 4-speed. I've also installed a 3-speed brownie for the overdrive. I hope to get it on the road sometime this winter.
Mark
Old 08-04-2014, 07:11 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to behold
Let me be the first to welcome you to the forum. Glad to see another F4 being put back on the road. That Mercedes diesel and overdrive transmission should make a nice road friendly package.
Edit: And of course, you know about the widow makers.
__________________
Ray
1949 F-4 Built to drive--script bed.
1956 F350 Stock rebuilt script bed
2007 F150 SC. Driven once in a whle.
So, how is this PC stuff working out for you, America?
Old 08-04-2014, 07:17 PM
BradsF1 BradsF1 is offline
BradsF1 is starting off with a positive reputation.
How is that Mercedes diesel for power? Which diesel is it? Welcome to the forums.
Brad
Old 08-04-2014, 07:20 PM
49fordv8f4's Avatar
Thanks for the welcome. I did buy a set of 19.5" wheels from a local salvage yard. I did have some pre '48 20" split rims I could have used but, I wanted to run radial tires.
Mark
Old 08-04-2014, 07:26 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 is a splendid one to beholdtruckdog62563 is a splendid one to beholdtruckdog62563 is a splendid one to beholdtruckdog62563 is a splendid one to beholdtruckdog62563 is a splendid one to beholdtruckdog62563 is a splendid one to behold
Add my welcome. Glad to have you, and glad to have another big model saved. Stu
__________________
Stu McMillan
'52 F-3 Marmon-Herrington 6R32-4 - in progress
'51 R3-4; '51 LD7-4 Ranger; '50 R3-4 - pending projects
'51 F-3; '51 F-3; '52 R32-4, '53 6M254 -parts/donors
'97 F-250 4WD/460/ZF5 - trailer duty
'03 E-450 Fun Mover; '07 E-350 parts hauler; '13 E-350 Lab taxi
Old 08-04-2014, 07:28 PM
49fordv8f4's Avatar
Brad, The engine I'm using is a 3.0 liter 5 cylinder turbo diesel. If I remember correctly it has 125HP and about 225ft lbs of torque. It is real similar to the '53 mercury v8 for power but at a higher rpm. I hope it will run good in the truck, it ran real strong in the car I took it out of. The Mercedes car weighs about as much as the truck.
Thanks for the welcome, Mark
Old 08-04-2014, 07:35 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.FortyNiner has a great reputation on FTE.
Welcome! I admire your mechanical skills. Good luck with the build.
Old 08-04-2014, 07:41 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a good reputation on FTE.38 coupe has a good reputation on FTE.
Welcome! Can you post pictures? I'd like to see your aux box installation. Which transmission do you have (Spicer, Watson, other...)? I'm curious about your five cylinder diesel installation too.
Old 08-04-2014, 07:46 PM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 is gaining momentum as a positive member of FTE.Marauder2004 is gaining momentum as a positive member of FTE.
Welcome and I too am glad to hear of another F4 being saved and put to good use. As has been already said, we really like pictures!
__________________
Howard
1948 Ford F4
1992 F-250 HD 5.8 4x4
2004 Mercury Marauder 32v DOHC - sold in June. Don't create a screen name after a car you might sell!
1969 Marquis convertible, 429
Old 08-04-2014, 08:00 PM
Harrier's Avatar
Harrier Harrier is offline
Harrier is a name known to allHarrier is a name known to allHarrier is a name known to allHarrier is a name known to allHarrier is a name known to allHarrier is a name known to all
Welcome to FTE. The larger trucks have a great appeal. Those of you that restore them have a lot of respect in my book.
mechmagcn is also from Arkansas and he has a Mercedes diesel in his truck and took it all over the country. His is a little F100 though.
http://www.ford-trucks.com/forums/1151782-how-far.html
Pictures, we love pictures!
__________________
Joe
1955 F-250 239 Y-Block
Y-Block Restoration Thread
Old 08-04-2014, 08:29 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
I'm with Ross...
Jolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to beholdJolly Roger Joe is a splendid one to behold
Welcome to FTE from California!
We really want to see some pics of your diesel / brownie / original 4 speed.
Is that a crash box tranny or a synchro? Really interested to see the mating of the diesel to that tranny.
I see lots of F4 owners have already said hello.
__________________
Joe
1951 F4 "Betsy" Build Thread @ http://www.ford-trucks.com/forums/10...4-project.html
Old 08-04-2014, 10:58 PM
TireDood's Avatar
TireDood TireDood is offline
TireDood has a good reputation on FTE.TireDood has a good reputation on FTE.
Welcome to the best forum in the world for these old trucks! I'm in northeast Arkansas, glad to see another Arkansan on here.
Old 08-05-2014, 11:10 AM
arctic y block's Avatar
arctic y block arctic y block is offline
Old School
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Subscribing in hopes to see some pic's. That sounds a lot like the engine Jeff used in his F1.
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Sold for 9.5K
Don't just Modify it Fordify it
A Side Arm Is Like A Parachute, Tis Better To Have One An Never Need It, Than To Need One And Not Have It
Old 08-05-2014, 11:53 AM
49fordv8f4's Avatar
Thank you for all the replies and hearty welcomes. I will try to post a few photos.
Click the image to open in full size.
This is the engine adapted to the truck 4-speed. I used a stamped steel bellhousing for an H flathead 6 so I could cut and modify it. I machined an adapter for the crankshaft to use a 460 neutral balance flywheel. The starter is an FE series starter. I rotated the bellhousing slightly to raise the starter to the Mercedes starter position. The pan is too wide for it to be any lower.
Here is a view of the engine setting in the truck.
This is the crossmember for the Mercedes motor mounts.
Once I get everything connected the way I want it, I will pull the engine back out and clean it up and replace some of the gaskets and seals. I will also send the Mercedes flywheel and the Ford flywheels off and have them match balanced.
Thanks for looking, Mark
Old 08-05-2014, 12:09 PM
49fordv8f4's Avatar
To answer a few questions. My auxiliary transmission is a Spicer 5531. I don't have any photos of the mounts for it , I will see if I can take some. I added another transmission crossmember and mount, from another truck frame I had, for the front mount on the Brownie. I made crossmember , that uses the front motor mounts for a flathead, for the rear of the transmission.
I am replacing the original T9 Warner 4-speed with a T98. I don't mind double clutching but as I get older my knee is acting up some so I thought it would be happier.
Thanks, Mark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Hello from Russellville Arkansas! drasm22 New Member Introductions 5 06-27-2014 09:45 PM
Head stud installers in Oklahoma/Missouri/Texas? 04SixPointSlow 6.0L Power Stroke Diesel 6 04-14-2014 05:10 PM
Noobie / old FTE member 67M250Highboy Arkansas Chapter 35 02-04-2012 09:08 PM
1952 Kansas Navy Ordnance F6 rla337 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 06-09-2008 10:38 PM
Drop Axel 49F1Flathead 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-04-2008 11:37 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
