Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 08-05-2014, 12:18 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is online now
Kentucky Chapter Member
EffieTrucker has a great reputation on FTE.EffieTrucker has a great reputation on FTE.EffieTrucker has a great reputation on FTE.EffieTrucker has a great reputation on FTE.
Nice work! The picture with the firewall makes me want to see more of the truck.
__________________
“The rat rod is a whole lot of fun, in theory, until someone forces you to actually drive it.” - David Freiburger, Hot Rod Magazine
Old 08-05-2014, 12:21 PM
49fordv8f4's Avatar
49fordv8f4 49fordv8f4 is offline
49fordv8f4 is starting off with a positive reputation.
Here are a couple more photos.
Click the image to open in full size.
This is the Mercedes engine oil cooler mounted in front of the radiator
This is the Mercedes throttle linkage adapted to the original truck throttle.
This is the boost pressure gauge, exhaust temp gauge and glow plug light in a plate I adapted to the speaker grill. I will paint it the same color as the grill.
Thanks again, Mark
Old 08-05-2014, 01:38 PM
pweng1's Avatar
pweng1 pweng1 is offline
Coe owner and builder
pweng1 is starting off with a positive reputation.
looks good. You are breaking new ground here you have our attention. Keep sending the pics.
Old 08-05-2014, 02:24 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to beholdraytasch is a splendid one to behold
Beautiful project. Keep the detail updates coming. And to think this truck could very well show up at a future TS event.
__________________
Ray
1949 F-4 Built to drive--script bed.
1956 F350 Stock rebuilt script bed
2007 F150 SC. Driven once in a whle.
If there’s one thing that the government is highly skilled at, it is creating excessive amounts of bureaucracy and extra layers of red tape for people to wade through.
Old 08-05-2014, 02:34 PM
christurney77's Avatar
christurney77 christurney77 is offline
christurney77 has a good reputation on FTE.christurney77 has a good reputation on FTE.
49fordv8f4.... Glad you finally joined in... Guess I need to start a building thread to show you guys what I've been working on...
__________________
chris
1946 Ford 1/2 ton "Earl"
1952 F-1
build thread - http://www.ford-trucks.com/forums/11...ar_earl-s.html
arctic y block's Avatar
arctic y block arctic y block is offline
Old School
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
This is so cool. Where is Jeff. I have the spec's on his engine somewhere but alas I can't find them. Sure seems like the same setup except Jeff has a slush box in his. I would love to scrap the wizzer in my Bronk and put in an oil burner and 5 speed. If not for the transfer case I would also put in a 3 speed aux box. Ya just can't have to many sticks with 3 peddles I say. I ran an Autocar back in the day with three sticks. That was a blast from the past it was.
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's
62 Uni 390 C6 Custom Cab Sold for 9.5K
Don't just Modify it Fordify it
A Side Arm Is Like A Parachute, Tis Better To Have One An Never Need It, Than To Need One And Not Have It
Old 08-05-2014, 02:41 PM
Old School
I sent Jeff a message to check in here. Hope ya get it bud. My puter is vewy vewy sic. As Elmer would say.
__________________
Old 08-05-2014, 02:46 PM
I gave our new member his info several months ago Arctic... Don't know if they ever chatted though...
__________________
chris
1952 F-1
Old 08-05-2014, 06:27 PM
49fordv8f4's Avatar
38 coupe, the spicer transmission is a 5531 without any suffix letter. 2.0 to 1 in 1st, 1 to1 in 2nd and .72 to 1 in 3rd. here are a couple of photos of the mount. I still have to paint it and the transmission.
Front mount
rear mount
My rear driveline is assembled to the correct length, I need to weld and paint it. The front driveline will need to be cut again since I changed to the T98 4-speed. It is about 2" longer than the T9 that came in the truck.
Thanks, Mark
Old 08-05-2014, 06:34 PM
49fordv8f4's Avatar
Here are a couple of photos of the cold air intake I'm working on.
I'm using 3" stainless mandrel bent exhaust tubing and silicone ells and connectors. I will make flanges for the "U" tube, that goes thru the inner fender, and have them TIG welded on so I can fasten the tube to the inner fender and seal out dirt from the wheel well.
Thanks, Mark
Old 08-05-2014, 06:46 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a good reputation on FTE.38 coupe has a good reputation on FTE.
Thank you for the pictures. That is a clean installation.
I have a Spicer 5831 with the same ratios that I dream of installing in my F-2. I am concerned about the height. I looks like you were able to tuck the auxiliary up under the cab very nicely. I hadn't thought about doing a low mount on the front, but it makes sense when I see it. It looks like it gives you a little more clearance for the shift rods.
Old 08-05-2014, 06:49 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo is a splendid one to beholdtopmoo is a splendid one to beholdtopmoo is a splendid one to beholdtopmoo is a splendid one to beholdtopmoo is a splendid one to beholdtopmoo is a splendid one to beholdtopmoo is a splendid one to beholdtopmoo is a splendid one to behold
Absolutely beautiful work! Nice to see completely different approaches to these trucks.
  #28
Old 08-05-2014, 10:22 PM
49fordv8f4's Avatar
Thanks for all the kind words.
Chris, you do need to show everyone your F1 build. That's going to be a nice ride.
38coupe, The 5831 is a newer version of the 5531 I have. Parts may still available for yours. I have the transmission mounted high enough that I will have to drill two holes in the crossmember under the cab to run the shift rods thru. Your 5831 would work really well in your F2.
Thanks again, Mark
  #29
Old 08-06-2014, 05:58 AM
Harrier's Avatar
Harrier Harrier is offline
Harrier is a name known to allHarrier is a name known to allHarrier is a name known to allHarrier is a name known to allHarrier is a name known to allHarrier is a name known to all
Wow! Thats impressive. Keep those pictures and details coming. I love seeing what you skilled builders are doing.
Chris, Yeah, you need to start a build thread on your F1.
__________________
Joe
1955 F-250 239 Y-Block
Y-Block Restoration Thread
  #30
Old 09-03-2014, 08:49 PM
38 coupe's Avatar
Do you have any updates on your truck? Inquiring minds want to know!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Hello from Russellville Arkansas! drasm22 New Member Introductions 5 06-27-2014 09:45 PM
Head stud installers in Oklahoma/Missouri/Texas? 04SixPointSlow 6.0L Power Stroke Diesel 6 04-14-2014 05:10 PM
Noobie / old FTE member 67M250Highboy Arkansas Chapter 35 02-04-2012 09:08 PM
1952 Kansas Navy Ordnance F6 rla337 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 06-09-2008 10:38 PM
Drop Axel 49F1Flathead 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-04-2008 11:37 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
