Why remove air pump? - Ford Truck Enthusiasts Forums
Old 08-04-2014, 06:44 PM
One Sock One Sock is offline
One Sock is starting off with a positive reputation.
I've seen a few threads about HOW to remove or gut the air pump (smog pump), but none of them really address the WHY. Has anyone done this and got better mpg, or a noticeable performance improvement?
Old 08-04-2014, 06:56 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
If you have removed or gutted the cat, the air pump is pretty much jusr dead weight and a paracidic draw of power from the belt.
Old 08-04-2014, 08:56 PM
Shadow944795's Avatar
Shadow944795 Shadow944795 is offline
Shadow944795 is starting off with a positive reputation.
Quote:
Agreed, once the old stock cats are removed or gutted out the air pump is useless and unless you live in an area where the smog ****'s won't let you remove it and pass the test I say delete it and call it done. All you need is a shorter belt.
Removing pulley on smog pump on 460 mwilliams0326 1987 - 1996 F150 & Larger F-Series Trucks 10 02-21-2016 01:51 PM
Air pump (and all EGR stuff) removal on 5.8.... mikeberman04 1978 - 1996 Big Bronco 37 02-16-2016 10:22 AM
Purpose of air deflector under oil pan? caprang 2011 & Newer Explorer 2 07-01-2015 08:05 AM
egr delete/bypass Tater7633 1987 - 1996 F150 & Larger F-Series Trucks 8 04-24-2015 06:42 PM
460 air pump delete advice please Brnfree 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 04-12-2015 11:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
