1995 F-150, Suspension, Leaf Springs, 4 Leaf - Ford Truck Enthusiasts Forums
Old 08-04-2014, 05:11 PM
OFLM's Avatar
OFLM OFLM is offline
OFLM is starting off with a positive reputation.
<style> <!-- /* Font Definitions */ @font-face {font-family:"MS 明朝"; panose-1:0 0 0 0 0 0 0 0 0 0; mso-font-charset:128; mso-generic-font-family:roman; mso-font-formatther; mso-font-pitch:fixed; mso-font-signature:1 134676480 16 0 131072 0;} @font-face {font-family:"MS 明朝"; panose-1:0 0 0 0 0 0 0 0 0 0; mso-font-charset:128; mso-generic-font-family:roman; mso-font-formatther; mso-font-pitch:fixed; mso-font-signature:1 134676480 16 0 131072 0;} @font-face {font-family:Cambria; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:-536870145 1073743103 0 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:Cambria; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"MS 明朝"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-family:Cambria; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"MS 明朝"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} --> </style> I am cleaning and rust proofing the frame of my F150.
With everything taken off including the bed, now would be a good time to replace the leaf springs if necessary. The truck has 84,000 miles and I cannot see any obvious sagging of the rear and I don't expect to be hauling heavy loads. However, if there is a good reason to replace the 4 leaf springs now, I will.
Do the springs on these trucks have any inherent problem with weakening of the springs over time, or is there any other reason(s) I should replace the leaf springs?
Your experience and suggestions would be appreciated.
Old 08-04-2014, 06:39 PM
GoinBoarding GoinBoarding is offline
GoinBoarding is gaining momentum as a positive member of FTE.
I replaced mine when a 500lb load made her squat and 1000lbs damn near put it on the bump stops. If yours aren't broken (no cracked leafs) and you don't have any issue with their weight bearing ability I wouldn't replace them. Take a look at the bushings and the spring pads, make sure they're not all worn out bc now would be an easy time to replace them.
You definitely want to take a good look at the rear spring hangers, they are cup shaped and hold water/salt/dirt so they rot pretty easily.
Old 08-04-2014, 07:09 PM
SteelHorse4x4's Avatar
SteelHorse4x4 SteelHorse4x4 is offline
SteelHorse4x4 is starting off with a positive reputation.
Hey OLFM, how's the frame clean-up etc. going? Did raising the cab up a little on each side work for you?
Old 08-04-2014, 07:48 PM
OFLM's Avatar
Quote:
Lets just say I am in the process up to my neck. I started cleaning rust by leaving everything attached. I decided it would be a good idea to take the drive shaft out and replace the U-joints. Drive shaft was rusty and I cleaned primed and painted it. Wow! That looks good. Can't have a good looking drive shaft with the rest rusted.
So now I have all of the gas tanks out. Differential laying on the driveway. Bed has been removed. All brake, vent and fuel lines are loose. Started grinding out rivets yesterday. I have been reconditioning parts as I take them off. The job has been really dirty so I can't do it in my garage since it is connected to the house. So I have been working in the drive way. Hoping not to get thrown out of the neighborhood. I'm originally from West Virginia so I am good with it.
The picture below is before the rear tank was taken out.
I am slowly working my way up to the cab and I will try lifting the cab as you suggested.
BE WARNED.. Don't think "I'll just replace that U-Joint" when you really hate seeing rust on the frame. Next thing you know your truck is in a 1000 pieces.
Help! I've gone nuts
Old 08-04-2014, 08:04 PM
I feel your pain. LOL Its like everything you touch can, should, and damit will be better. All the while saying to yourself, "Why Did I Have To Look There Too" On a side note, with your springs, head to the JY and grab a couple more leafs to add to your packs, just a thought.
http://www.ford-trucks.com/forums/at...1&d=1407200481
Old 08-05-2014, 08:39 AM
ATS Junior's Avatar
ATS Junior ATS Junior is online now
SPONSOR
ATS Junior has a very good reputation on FTE.ATS Junior has a very good reputation on FTE.ATS Junior has a very good reputation on FTE.ATS Junior has a very good reputation on FTE.
Exactly what he said. If the springs aren't giving you a problem and you are not looking to haul much with the truck than I'd leave them alone. Definitely look at the bushings, see what the condition of those are. If they are in bad shape, replacing them will make a world of difference.
-Junior
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
Old 08-05-2014, 09:40 AM
1995F150XLT4x4's Avatar
1995F150XLT4x4 1995F150XLT4x4 is offline
1995F150XLT4x4 is gaining momentum as a positive member of FTE.
Personally if I were in that deep I might consider replacing them now, because inevitably in the future they will sag. If you've got the money I'd almost just throw an add-a-leaf kit in or throw a couple salvage yard leaves in to beef up the packs.
Growing up, it was always .. "if it ain't broke, don't fix it"
Your call though!
Transmission worries! pjcat Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 10-03-2015 12:48 PM
Drivers seat belt retractor part number zapola6 Excursion - King of SUVs 0 05-02-2015 04:40 PM
vacuum regulator valve knash0727 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 01-27-2015 02:03 PM
'99 F150 Replacing Ignition Actuator BDB513 1987 - 1996 F150 & Larger F-Series Trucks 1 07-21-2014 04:38 PM
NE Georgia Swap Meet, Aug 4 Brad54 Events & Happenings 0 08-01-2012 12:58 AM
Tags
1995 f-150, 4 leaf, leaf springs, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
