FNG 6.4 ills - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
FNG 6.4 ills
Old 08-04-2014, 05:49 PM
Baudoux Baudoux is offline
Baudoux is starting off with a positive reputation.
FNG 6.4 ills
I have a good friend that bought a 2009 F350 6.4 4x4 automatic. It is a service truck for his well drilling business. Since I keep his fleet running, I asked him not to buy a 6.0/6.4, so of course he bought one. He called me 2 years ago, he had filled it with gasoline and it quit a block from the station. Had it towed to his shop, I drained the tank, changed all the filters, and it has been running every day since. Last week it started throwing p0088 and p0500. The driver tells me that the cruise will drop out, and the truck will lose power. Shut it off and restart and it is ok for a few miles. I have visually inspected the harnesses, and verified 5v at the connector on the right valve cover, and replaced the VSS at the the transmission output. My concern is that it looks like VSS and fuel rail pressure sensors are pins 39 and 40 at the PCM. How do I identify the connectors at the PCM? My Mitchell diagram shows C1232B and C1232E.
Old 08-05-2014, 10:54 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
It is going into limp mode. I would find the cause of the p0088. Check for metallic glitter in the filter filter. There is also a updated pcm flash for some issues with the p0088.
Old 08-06-2014, 08:19 AM
Thanks for the reply. I changed the filters last week, before I knew to check them for metal. I will check them again, since it has been run a hundred miles or so. It concerns me that there are two codes, the p0500 sets almost immediately on a drive after clearing, and the p0088 takes a while longer. All of the speed sensors read the same on the Modis. The cab has been off at least twice by other shops, for other issues. I want to be real sure before I take that step. I am a one man shop with too much other work to make a mistake on this one. I have spent some time researching, and I will ohm the harness today, after I check the filters.
Old 08-06-2014, 11:08 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
P0088 is the first sign that either the HPFP is going south or probably the VCV is bad and cannot regulate the pressure correctly.
First fix is the do a reflash of the pcm. That will change the reading the pcm takes. If that does not work then a new hpfp is the fix.
But..check those filters and the bowl for metal or rust first.
Old 08-06-2014, 04:44 PM
Thanks, I appreciate the help. I spent some more time on the wiring, and I see that the ABS VSS and the fuel rail pressure sensor signal wires are in two different connectors, so my suspicion of trouble between the two appears to be unfounded. The filter under the hood is clean and there is no evidence of contamination in the bowl. I am taking to a Ford dealer for a re-flash to the latest and greatest. I will keep you posted.
Old 08-11-2014, 11:30 AM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
The 6.4 pump seems to fail electronically, but seems to be built stronger mechanically than the 6.7 pump. IMHO.
Vss help needed pcm swap/c6/9" FossenRacing 1987 - 1996 F150 & Larger F-Series Trucks 2 08-18-2015 10:13 PM
DTC P-0605 "ROM ERROR" saying REPLACE PCM : ? MAD JAX Modular V10 (6.8l) 4 02-01-2015 12:21 PM
My new instament cluster avf100 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-22-2014 12:42 PM
train that hit a deer! my85fordIDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 09-15-2011 03:56 PM
Mitchell Gear Splitter work on my truck? jdbanks Clutch, Transmission, Differential, Axle & Transfer Case 2 05-17-2005 03:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
