Suggestions on Dolphin gages in 52 F-1 - Ford Truck Enthusiasts Forums
Old 08-04-2014, 03:16 PM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
I am about at my wits end trying to make all the stock gages work correctly in my 52 F-1.
If I cannot trust the temp, oil & gas gages to give me the correct readings I just don't think I can live with it!!!
I really would like to keep it stock looking but don't think it is possible for me with 12 volts on a 302.
I have the electronic voltage reducer on the gages but still not getting anywhere close.
Anyone using these?
Any suggestions?
TractormanBill
Old 08-04-2014, 03:28 PM
wallster's Avatar
wallster wallster is offline
wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.wallster has a very good reputation on FTE.
I have them in my '51 and they seem to work perfect. Dolphin's instructions/owners manual is pretty much non-existent though. You will have to alter the sending unit if you're using the tank behind the seat since the bolt pattern and diameter mounting plate on the sending unit doesn't fit.
My last '51 used an under dash oil pressure gauge and an under dash temperature gauge which also worked perfect. Both trucks were converted to 12 volt systems with "modern" engines.
Hope this helps.
Wally
Old 08-04-2014, 04:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Bill, the stock gauges will work fine, look for NOS or good used. If they didn't work on 6v they won't work on 12v.
Old 08-04-2014, 08:21 PM
tractorman
gages
What is NOS?
Anybody used the NVU gages?
TractormanBill
Old 08-04-2014, 11:27 PM
ALBUQ F-1's Avatar
postin' fool
NOS = New Old Stock, Ford factory replacements still on the shelf. Since the '51 - '52 gauges were used into the '60's on bread trucks, there are a surprising number of NOS units still around.
Old 08-05-2014, 01:06 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
Hope this helps.
Wally
You can get an adapter plate to match up the new Dolphin sending unit. Speedway Motors has the part: 1935-1956 Ford Fuel Sender Adapter - Speedway Motors, America's Oldest Speed Shop
Dan
Old 08-05-2014, 01:09 AM
old_dan's Avatar
By the way....I also put in the Dolphin gauges. I haven't had any problems either.
Dan
Old 08-05-2014, 10:25 AM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
Quote:
Originally Posted by tractormanbill View Post
What is NOS?
TractormanBill
Bill, I received a set of NVU gauges the other day. Very happy with their quality and appearance. Haven't installed them yet so can't comment on operation. They did come with all senders except the fuel as I ordered for Ford. If you get a Chevy set the fuel sender is included.
Old 08-05-2014, 01:25 PM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
i put the Dolphin's in my 48. The gas guage is a little lazy but so far they are working OK.
Suggestions needed for door handle shaft repair tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-27-2015 09:34 PM
What to do with stock running 52 F-6 with V8 tractormanbill Texas Chapter 4 08-25-2014 11:53 PM
Dash gages in 52 F-1 with 12 Volt tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-30-2014 03:34 PM
fule gage DET.CAVEMAN 1973 - 1979 F-100 & Larger F-Series Trucks 11 02-05-2014 01:06 PM
New vent window frames for 52 F1 tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 09-03-2013 11:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
