Fuel/oil type hose in the cooling system - Ford Truck Enthusiasts Forums
Old 08-04-2014, 12:51 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
I recently had to replace the small tube with hose connections that goes over the radiator and seemingly into the throttle body warmer as it developed a crack and started leaking badly. As I was unable to find normal heater rubber hose I used some rubber fuel/oil line hose. Should I be worried and considering this a temporary fix?, I did travel 200+ miles with it this weekend and it all seems to be working just fine.
Old 08-04-2014, 01:05 PM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
Is it oil cooler hose or just fuel line like for a lawn mower?
Oil cooler hose is actually better than cooling system hose. Rated for higher pressure and it can take the relatively low temperature of coolant too. Relatively low compared to the temperature of most oil systems, that is.
Old 08-04-2014, 01:23 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
I wouldn't be I replaced that line on my 94 shortly after I bought the truck, the metal section running over radiator was questionable at best = more rust than metal.
I replaced the line with fuel line and its been there for many years now. I used good quality reinforced rubber fuel line and its still solid as the day I put it on there.
Old 08-04-2014, 09:48 PM
1992forever 1992forever is offline
1992forever is starting off with a positive reputation.
I also used fuel line to replace this line and while it worked just fine it eventually became very hard. I was not able to find the proper cooling hose for it when I needed to do the original repair so this is why I used the fuel line. I have since replaced it with the proper cooling system hose and it has also worked well but is still flexible. If you can find the proper cooling system hose I would use it over the fuel line.
Old 08-04-2014, 11:10 PM
Encho's Avatar
I guess I'll keep it for a while then, it seems to work fine. Just wanted to make sure I wasn't doing something utterly stupid.
Buying upgrades. sudsmcduff 1999 - 2003 7.3L Power Stroke Diesel 13 02-09-2016 02:16 PM
Maine's December Christmas and SNOW Thread! ToMang07 Maine Chapter 127 01-01-2015 08:29 AM
Fuel/oil filter housing 2006White60 6.0L Power Stroke Diesel 4 05-21-2014 12:19 PM
Fuel/Oil Additives socalfordguy2003 6.0L Power Stroke Diesel 2 09-14-2013 09:42 AM
Do most use torque wrench on fuel/oil filter caps? danocross 6.0L Power Stroke Diesel 22 12-20-2010 05:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
