7.3 OBDII in CA? - Ford Truck Enthusiasts Forums
7.3 OBDII in CA?
Old 08-04-2014, 01:45 PM
GuitarJesus's Avatar
GuitarJesus GuitarJesus is offline
GuitarJesus is gaining momentum as a positive member of FTE.
7.3 OBDII in CA?
does anybody know if the 1997 model year powerstroke was the newer OBD for California models? I think I read something from Ford a while back that California was the only state that the diesel got the newer on board diagnostics.
Old 08-04-2014, 02:20 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
A post from subford on a different thread: http://www.ford-trucks.com/forums/13...l#post14467770
Old 08-04-2014, 02:34 PM
Thanks man, so I was right. OBDII in CA for 97' earlier years had an OBDII style connector but was a unique system for PSD
Old 08-04-2014, 02:42 PM
Crewcabber's Avatar
Crewcabber Crewcabber is offline
Crewcabber is gaining momentum as a positive member of FTE.
Its all based off of weight. My 97 7.5 is OBD1
Old 08-04-2014, 02:44 PM
On the document I read from Ford in 96 and 97 gas engines in California under 14000 gvwr were OBDII. 97 diesels were OBDII for under 14000 gvwr
Old 08-04-2014, 02:52 PM
Here is the document I had found a while back.
https://www.dropbox.com/s/ox7cdf2twf8ee86/DOBDSM971.pdf
Old 08-04-2014, 03:41 PM
rla2005's Avatar
Quote:
The OP specifically asked about "powerstroke" aka diesel. Gas engines are a completely different ballgame.
Old 08-04-2014, 03:43 PM
Crewcabber's Avatar
I have read so many articles saying that my truck is an obd 2 and had people tell me the same thing. I fought with two smog shops over the smogging of the truck. I took it back to the shop the p.o. used to have service and smog it and voila smogged it a an obd1. The obd2 trucks are maf and have I believe two o2 sensors as well as the plug in the cab under the dash.
My truck is speed density and has one o2 sensor and has the 2 plugs under the hood.
One smog technician I argued with told me he was going to report me to carb and be cause my trucks emissions and computer had been tampered with needless to say he ate his words when I took the smog report back to him and showed him it smogged as obd1.
Old 08-04-2014, 03:45 PM
Crewcabber's Avatar
Quote:
Not necessarily when it comes to the obd1 and obd2 in California.
(the smog ****'s state)
Old 08-04-2014, 03:54 PM
Crew, I'm guessing your truck wasn't sold originally as a CA truck. The only 96-97 7.5's I've seen here in CA that were OBDI are trucks that were originally from other states.
Old 08-04-2014, 03:56 PM
Crewcabber's Avatar
My last 97 crew cab f350 7.5 was obd1 as well. It was sold and bought in california.
Old 08-04-2014, 04:03 PM
I'm curious if Ford just used parts on hand towards the end of OBS production
Old 08-04-2014, 04:11 PM
Crewcabber's Avatar
Ford has done that since the 40's. Chevy has done iy since the early 30's. Probably even earlier than that but those are the years I know I have seen them use parts from the previous years.
Old 08-04-2014, 04:21 PM
Sounds like my Fender and Marshall guitar amps. In the 60s if they ran out of a certain value capacitor they'd use something else, contributing to each amp's unique tonal character.
Old 08-04-2014, 04:31 PM
Crewcabber's Avatar
A little off topic but I have a 95 ranger that is obd2. According to most of the reading ford trucks started obd2 in 96. I look at it like this fords are like a box of chocolates. You know the rest of that story.
Pink slip portagoosey 1961 - 1966 F-100 & Larger F-Series Trucks 5 03-09-2016 12:19 AM
california emmissions sparke454 2015+ F150 8 01-10-2016 02:53 AM
modesto, california craigslist 1948 F4 for sale mrcman58 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 09-10-2015 10:04 PM
Anyone have a part number for 7.5l Harmonic Balancer w/OBDII? GuitarJesus 1987 - 1996 F150 & Larger F-Series Trucks 7 02-21-2015 12:25 PM
Engine swap? Redneck Romeo 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-30-2011 12:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
