Planning a couple things, need some help..
Morning guys, I've accumulated a couple pieces and parts that I'm gunna bolt up when I have evening else together. I got a replacement TS Chip after the one I originally ordered was toast, I've got the 6637 with the NAPA 45 and a prefilter cover, and I've got to order/find a new A-pillar cover for the drivers side; mines cracked at the lower screw. So, two questions:
1. Has anyone purchased the triple gauge A-pillar trim for our trucks on EBay that are color matched for the light brown? Seems like there is one in particular that's prominent. Or, would anyone have a preference on a color matched triple gauge set-up? I'll be installing the TS dial in one and the existing pyro and boost in the others. Another option would be buying a decent black one and color matching myself. If I went this route would anyone happen to have information on the paint I'd need? Ideally what I want is a tripple gauge pod that does not "fit over" but replaces the factory trim and (this is really reachin) has one blank hole, but that's probably askin too much. I would assume one can buy blanks; correct? Course something like this would be excellent!
http://www.thedieselstop.com/forums/...memade-241177/
2. I've seen some discussion about relocating the CCV and perhaps something else with regards to the 6637 conversion. What I'd like to do is keep everything congregated to that area. Has anyone kept the ccv and other associated plumbing routed to the new 45 degree pipe? If so would anyone happen to have any pics, grommet part #s or threads that would talk about this specifically?
Thanks for the help guys.
I did the same thing for my red interior. i used a spray meant for plastic, 3 coats and done, perfect match.
CCV currently is installed downstream of that 45* elbow. If your not running an intercooler you should leave it in the stock location
OK so its more twards the turbo anyway? I'm not running an intercooler so that'd be fine.... Thanks.
on
I actually have a CCV eliminator kit. Its just a big aluminum tube with the mounting brakets for the factory mounting holes, them you take off the CCV reverse it and run 5/8 heater hose out back along the frame rail, zip tie a rag around it and let the engine blow anything out the end of the heater hose. It's nice cause there's no restriction in the connector between the turbo and air box, straight thru. you can have it, i doubt I will be needing it.
CCV can stay in the stock location when you put the 6637 in. You want to do away with it when you install an IC but for just the filter it can stay put. Like was said above the CCV goes into the aluminum elbow that goes over the valve cover. The 45* that you will need goes between the filter and the black rubber flex pipe that attaches to the aluminum piece that you leave. Make sense? You're installing the filter and the 45* that goes into the filter in the picture above.
I would go ahead and do the ccv mod, that way you would already have it done when you get an ic. It is pretty easy. And there is companys out there that sell the led switch indicator. No limit is one i can find right now, but im gonna try and find the other company i have seen make them.
