Planning a couple things, need some help.. - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-07-2014, 08:44 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Sorry Corey, the only ones I have ever used fasten over the stock pillar. Let me know if you need a stock pillar and I may be able to find one in decent shape.
I swear that someone makes one that replaces the whole piece. I don't recall if it is ISSPRO or Autometer or who makes it, though.
Old 08-07-2014, 08:57 AM
coreyallan01's Avatar
coreyallan01 coreyallan01 is offline
coreyallan01 is gaining momentum as a positive member of FTE.coreyallan01 is gaining momentum as a positive member of FTE.
Thanks! I DO need a tan one; if you have access to some I'd be all over it, man those things are hard to find! My double pod that installs over the factory trim fits pretty good, maybe I should just find a triple and color match it. Its tough to verify fit and finish when your just looking at pictures. + I'm only a member here so it's not like I have a pool of resources to pull from..
Old 08-07-2014, 09:13 AM
If you're going to color match the triple pillar pod could you also color match the OEM pillar cover? I might know where I could find a tan one, but I can't say for sure. The nice thing about color matching it is that you would be able to clean it up and do all your fitting and then paint it all together.
I just have a cheap triple pillar pod in my truck now, and I had to add some extra screws to get it to fit like I wanted it to, but I don't think it looks bad. I used the screws that were supplied with the pod along the front and used the little caps for the screws then I used some other little screws for along the windshield where no one can see it anyway. I know it's totally a personal preference thing, but I left mine black because I like the contrast it provides. It kind of ties into the gauge cluster being black as well. I could go either way on them I guess.
Old 08-07-2014, 09:28 AM
I hear that, the one I have now is black and your right; it does match the black parts of the dash fine. Eh... I don't know what I'm gunna do... Just keep thinking I guess...
Old 08-07-2014, 11:52 AM
farmert farmert is online now
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
The only pillar pods I have seen offered are the kind that lay over the factory pillar cover. Not what you are looking for I know.
Old 08-09-2014, 06:46 AM
So where do I plumb this to??
Old 08-09-2014, 07:41 AM
I can't tell for sure but is that the sensor in the air filter housing? If so that is just the IAT sensor (Intake Air Temp). You can twist it to remove it from the housing and then just wire tie it to the inside of the fender somewhere near where the 6637 filter will go. It will be reading the temperature of the air that is being drawn into the engine since it will be drawing air from that area of the engine compartment.
Old 08-09-2014, 02:31 PM
Ok cool, yeah it is.. I understand.. I'll do that then.. Thanks!!!
Old 08-09-2014, 09:20 PM
Quote:
Sure thing!
First Round Of Mods ... Have Questions Kingkong0192 1994.5 - 1997 7.3L Power Stroke Diesel 56 11-08-2015 10:02 PM
Interior spray paint?? coreyallan01 1987 - 1996 F150 & Larger F-Series Trucks 9 10-17-2014 03:42 PM
This weekend was like christmas! Awitte58 1994.5 - 1997 7.3L Power Stroke Diesel 28 07-15-2011 04:00 PM
GlowShift Gauges..... CLStewart144 1999 - 2003 7.3L Power Stroke Diesel 45 02-22-2010 01:13 PM
Matching Interior Plastic Paint les adams 1999 to 2016 Super Duty 5 12-16-2000 10:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
