Eliminating the through-bed bolts
Old 08-05-2014, 09:18 PM
Schuyles's Avatar
Schuyles
Schuyles is offline
Hi guys. This is for my '65 f100, but principle is the same....hopefully y'all have some ideas.
I am bolting my center crossmembers to the frame so I don't have to use the bolt that goes all the way through the bed wood, crossmember, and frame. What I'm confused about is how to bolt the front crossmember (by the cab-under the front bed panel) to the frame? Right now, the head of any bolt would protrude up into the bottom of the bed wood?
Any ideas how to bolt that front crossmember to the frame? Cut down the sleeve?
Old 08-05-2014, 09:23 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
It's a fairly simple process, just notch the crossmember where the bolt goes through so that the bolt head seats level with the top edge of the crossmember. Takes about a minute with a cutoff wheel. Once the crossmember is notched I dropped the bolt in place and weld it.
Here's a photo, kinda hard to see the weld but hopefully it will explain it a little better than my words.
Old 08-05-2014, 09:30 PM
Schuyles's Avatar
Schuyles
Schuyles is offline
Originally Posted by CharlieLed
It's a fairly simple process, just notch the crossmember where the bolt goes through so that the bolt head seats level with the top edge of the crossmember. Takes about a minute with a cutoff wheel. Once the crossmember is notched I dropped the bolt in place and weld it. Here's a photo, kinda hard to see the weld but hopefully it will explain it a little better than my words.
Yep, that's the only solution I could think of too. Thanks for the pic and response!
Old 08-05-2014, 11:10 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Om mine I just removed the sleeves since they were rusted out anyway. On the center supports i welded the lower plate solid to the channel and just used shorter bolts.
Makes a much cleaner look....
Old 08-06-2014, 06:06 AM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
On mine I also removed the sleeve as it is only needed when bolting through the wood.
Old 08-06-2014, 08:50 AM
Schuyles's Avatar
Schuyles
Schuyles is offline
Originally Posted by tinman52
Om mine I just removed the sleeves since they were rusted out anyway. On the center supports i welded the lower plate solid to the channel and just used shorter bolts. Makes a much cleaner look....
Thanks guys! I'm glad I was over complicating it!
I'll hopefully have a before/after of my new bed wood soon. This is a trial run so I'll be ready for the '56 later on. Luckily I already have most of the parts for my '56 bed because of getting the wrong parts from a vendor.
F100supercrew
05-24-2018 08:14 PM
jniolon
38
11-16-2017 12:12 PM
tjdad62
09-18-2014 01:54 PM
1982fordf100
03-23-2013 10:10 AM
glockoperator
11-30-2008 09:36 AM
Quick Reply: Eliminating the through-bed bolts
