1991 F250 w/ no power will not start - Ford Truck Enthusiasts Forums
Old 08-03-2014, 11:25 PM
FordFoolDave FordFoolDave is offline
FordFoolDave is starting off with a positive reputation.
Hey guys back again.
Same truck 1991 F250 XLT Lariat 4x4 w/ 460 7.5L V8.
Problem is this time, I'm getting no power to anything. I mean nothing. No buzzers, bells, whistles, lights, nothing.
I just replaced (with new parts mind you) the battery, starter solenoid, starter, battery cables (positive and negative) and now I'm at a loss.
I'm getting power to the solenoid after testing it, but it seems to end there. Frame to battery ground and block to battery ground are also good.
Also no blown fuses.
Any of you out there got a clue?
Almost at the end of my line here and about to drop it at a mechanics and see what tomfoolery they can come up with.
Old 08-04-2014, 08:35 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You put the all of the smaller wires with rings on the wrong side of the starter solenoid (relay). They all go on the with the battery cable from the pos (+) post of the battery.
Old 08-04-2014, 01:21 PM
I put them all on the wrong side? So if everything goes on the power side does that mean only the starter goes on the other side?
Old 08-04-2014, 04:14 PM
Alright so I switched everything around and I have power to the interior now!
Everything works as it should but when I go to start the truck nothing at all happens. No click from the starter or solenoid.
I tried jumping the posts on the solenoid and was met with a loud pop and spark but nothing else.
Seems like a grounding issue but the starter grounds to the bell housing and that's the only place that comes to mind where a bad ground would come into play. Especially since all grounds on the battery are fine and everything else works just fine.
Old 08-04-2014, 05:15 PM
subford's Avatar
Did you put the small push on wire back on the solenoid?
Old 08-04-2014, 05:17 PM
Yeah onto the top s post. The old solenoid only had one post but my new one has a top s post and a bottom I post. So I just put it back on where the other one was.
Old 08-04-2014, 05:39 PM
subford's Avatar
It goes on the "S" post.
Old 08-04-2014, 08:32 PM
Well its on the s post. All power is back to the interior. Just still won't start.
Old 08-04-2014, 09:08 PM
subford's Avatar
Have you tried putting power on the "S" post and see if it will crank?
Make sure it is park when you do that or if standard out of gear with the wheels blocked.
Old 08-04-2014, 09:15 PM
Yeah I tried it on both. Still nothing.
New members 2003 6.0 diesels starter won't engage. jeremy rowe 6.0L Power Stroke Diesel 30 10-22-2016 09:25 PM
Starter Solenoid Not Energizing Somemedic Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 12 07-04-2015 06:55 PM
4.9L Not Starting bcrone821 1987 - 1996 F150 & Larger F-Series Trucks 17 06-10-2015 02:55 AM
grounding problem. where are all my grounds? 91 ford f250 with 460/e40d ext cab Snacky 1987 - 1996 F150 & Larger F-Series Trucks 9 03-23-2015 08:39 PM
78 F150 Starting Issues Wooticus 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-17-2013 12:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
