Which would be more beneficial?
#47
Hehehehehe........
For sure...
We should all be on the 12 lug nut program. I'm thinking of building for my niece a 92-96 F150 shortbed, 302, AODE, and 8.8. Lowered 3/5. She can't complain if I give it to her, right?
Confessions?
- Do you doodle Dents, Bumps, and custom parts at meetings or boring classes?
- Have you used MS Excel to make parts shopping lists, junkyard lists, and vehicle to-do lists?
- Do you lunch at your desk so you can surf FTE, F'dification, and features/tech info at Custom Classic Trucks, Classic Trucks, and Truckinweb.com?
For sure...
Confessions?
#48
on
Confessions? - Do you doodle Dents, Bumps, and custom parts at meetings or boring classes? - Have you used MS Excel to make parts shopping lists, junkyard lists, and vehicle to-do lists? - Do you lunch at your desk so you can surf FTE, F'dification, and features/tech info at Custom Classic Trucks, Classic Trucks, and Truckinweb.com?
Excel? Yes, to create a shortcut formula for figuring out final drive ratios through transmission gears, axle gears and tire size.
Lunch at desk? I did. I would go straight to the library at lunch and research everything I needed to know about our fords.
#57
Is that their reproduction ones or the universal ones?
These are the type Im after
http://ts1.mm.bing.net/th?&id=HN.608...d=1.9&rs=0&p=0
Thank you by the way.
#60
on
These are what you can get at oreillys and autozone
http://m.oreillyauto.com/mt/www.orei...0314&ppt=C0329
