1997 f350 crew cab 4x4 diesel fuel tanks capacity - Ford Truck Enthusiasts Forums
Old 08-03-2014, 09:42 PM
sand1's Avatar
sand1 sand1 is offline
sand1 is starting off with a positive reputation.
How many gallons is the front and back tank?
Old 08-03-2014, 09:56 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
19 front, 18.5 back.
Old 08-04-2014, 12:05 AM
HOOTs95PSD HOOTs95PSD is offline
HOOTs95PSD is starting off with a positive reputation.
Do we have options for a bigger rear tank?
Old 08-04-2014, 12:32 AM
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
Home
Bronco tank. Have to lose your spare.
Old 08-04-2014, 01:12 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
There is also a 38 gallon for 87 pickups. http://www.amazon.com/gp/aw/d/B000C7...&robot_redir=1
Old 08-04-2014, 02:49 AM
Thanks for the links.. I saved them both. When I can get some down time on this truck it will be getting a bigger tank.
Would a fuel sender unit from the 88 truck hook right up to a 95's harness?
Old 08-04-2014, 07:40 AM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
If you buy the 38 gallon bronco tank like shown in the first link above you can re-use your factory pickup/sending unit. You just have to modify it to be longer (the tank comes with the necessary hardware to extend it) and make some new slots for the tabs to hold it straight.
I did the 38 rear tank and now I can hold 60 gallons under the truck!
Old 08-04-2014, 07:42 AM
I tried what I believe was a 80's sending unit and ended up running out of fuel with a half tank. I ended up doing what is written in the 'home' link above.
Old 08-04-2014, 08:39 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
i plan on doing this mod myself when rebuilding my truck.
Jim's write-up is quite clean, but is there really a need to extend the return line? i always like to dispense with extra work where possible :-)
Old 08-04-2014, 09:30 AM
Quote:
Originally Posted by OldWoodsDiesel View Post
i plan on doing this mod myself when rebuilding my truck. Jim's write-up is quite clean, but is there really a need to extend the return line? i always like to dispense with extra work where possible :-)
I think you would get some air bubbles forming while the fuel drops I to the last half of the tank. Also you may get siphon issues if the return is left out of fuel
Old 08-04-2014, 11:58 AM
i woudlnt be concerned with bubbles considering how the fuel sloshes around in there driving. back siphon is a good point, though!
Old 08-04-2014, 12:30 PM
The hardest part of modding the sending unit is the insertion of the extended rod thru the plastic part is keeping everything lined up. My original sending unit was falling apart and when I tried it, it fell apart. Believe you me, a new one is not cheap and I sweated getting the rod thru.
Old 08-05-2014, 03:43 PM
DarkStarMedia DarkStarMedia is offline
DarkStarMedia is gaining momentum as a positive member of FTE.DarkStarMedia is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by FI460 View Post
Home
My spare has been fine.....
Richard
Old 08-05-2014, 04:40 PM
FI460's Avatar
Quote:
Richard
Huh. Just repeating what I've read here.
Old 08-05-2014, 04:48 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
It can still be mounted, just lower than stock
Fuel Tank riser build question Samsn4 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-18-2016 03:38 PM
94 f150 4x4 dual tanks merbno Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 10-14-2014 05:36 PM
EXCURSION IN TANK MOD/DROPPING FUEL TANK 01EX Excursion - King of SUVs 11 06-28-2012 01:22 AM
92 F-150, duel tank fuel system Firefighter0513 1987 - 1996 F150 & Larger F-Series Trucks 6 02-05-2011 02:06 PM
gas tank help breedo99 1973 - 1979 F-100 & Larger F-Series Trucks 13 03-25-2010 09:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
