ZF 5 rebuild - Ford Truck Enthusiasts Forums
ZF 5 rebuild
Old 08-03-2014, 09:52 PM
bigcrunch bigcrunch is offline
bigcrunch is starting off with a positive reputation.
ZF 5 rebuild
The ZF-5 in my 1993 ( build late 92) 4x4 460 gas is pretty sloppy been used for lots of trailer pulling. I think it is a S5-42 but need to double check the tag if I buy a spare parts tranny out of a 2 wheel drive only dif is the main-tail shaft and tail housing?
Old 08-04-2014, 12:17 AM
Evan_P's Avatar
Evan_P Evan_P is online now
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
This might answer some questions.
ZF5 (S5-47) Rebuild - FSB Forums
Old 08-04-2014, 09:54 PM
Thats a very imformative writeup, so much I printed it on a color OCE' printer at work
Now I just some more info on parts interchange from 2 wheel to 4 wheel case.
Old 08-05-2014, 06:34 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
You do not need a parts trans.
Just get the standard rebuild kit which consists of bearings, syncros, and seals
zf5 swap to zf6 questions '97f350supercab 1987 - 1996 F150 & Larger F-Series Trucks 4 12-04-2016 09:06 AM
Zf5 swap Tyler.172 1994.5 - 1997 7.3L Power Stroke Diesel 7 12-24-2015 01:46 AM
Zf5 to zf6 swap XBAJBUSX 1994.5 - 1997 7.3L Power Stroke Diesel 23 10-22-2014 07:43 PM
ZF5 (S5-47M) Tail / rear extension housing transmission mount ears cracked NP Carling26 Clutch, Transmission, Differential, Axle & Transfer Case 1 08-11-2014 05:16 PM
zf5 tail housing cracked thedieselkid Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 08-01-2011 08:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
