Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
An update on my oil problem
  #76
Old 09-06-2014, 12:33 PM
fordpride's Avatar
fordpride fordpride is offline
Louisiana Chapter LDR
fordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud offordpride has much to be proud of
You have to remember that EOT is taking in between hpop and oil cooler. If you're seeing 220* the oil at the injector is a little hotter and thinner
__________________
Mike
Click here to join the Louisiana chapter
2014 RAM 3500 cummins
96 F350 CC ZF5 53k with grandpas package
Louisiana FTE Member Map
  #77
Old 09-06-2014, 04:20 PM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Quote:
Originally Posted by oldbird1965 View Post
The lowest tstat I could find was a 190° for the IH wp. My coolant is 210° when my oil is in the mid 220°'s. I'm afraid to look on Joey's site to see what duals would cost but I have to back out because of EGT's anyway. So, I don't see making any changes would do me any good except for water and oil cooler.
My bucking was slight, like when the tuner has the throttle response up to high, so in cruise it bucks.
I've looked at the price of duals a couple times. Ugh, I hope Joey can help me out and I don't have to go that route. I emailed him again a little bit ago since I haven't heard from him. I'm guessing he's gonna want my pump to check it out. Maybe I'm wrong, we'll see. If so that will have to wait a couple months.
__________________
Darin 99 ranger 76F250 66 fairlane
"TheBeast"1997F2504x4dually4.10's,160k,140VIDM,HPX ,4-5"dp, S366 turbo w/wicked wheel, 6637, elec. fuel,rosewood stage ones,php hydra,arp studs, comp springs, smith brothers push rods, honeybadgerjr hpop,riffraff res,melling lpop,180 tstat,6.0 fan and IC,trucool,coolant filter,scan gauge,lots of other gauges,racer x valve body and billet converter, upgraded trans, F550 leaf springs,SD dual tensioner upgrade, cold ac mod
  #78
Old 09-06-2014, 04:25 PM
For some reason I couldn't edit so another post.
My water was running 180 most all the time, creeped to 190 on the big hills. My oil was 180-190, then 190-200 on the big hills. Pretty much the same difference as you Glenn, just a little lower means it was nice. That's how it is when its hot too, maybe 10 degrees hotter on the oil side.
__________________
  #79
Old 09-07-2014, 02:28 PM
TerminatorEng.'s Avatar
TerminatorEng. TerminatorEng. is offline
TerminatorEng. has a good reputation on FTE.TerminatorEng. has a good reputation on FTE.
Darin, I agree with Travis. I don't think the oil reservoir spacer will help with this issue. If you need more capacity in the reservoir with a single pump, you may have a LPOP problem(volume supply). FWIW, I don't like the Melling LPOP. I had a bad experience with one, so never again. Talking with a few Dealers and friends with shops, they don't either, so I stay with OEM.
So, a couple questions: Your trouble is only when ICP is above 2800psi? If so, why not ask a Tuner for a 2800psi tune(or lower) and see if the stumble goes away, then we can make the next assumption/guess. I'm wondering what condition the injector poppet vlalves are in. If they bleed off at high pressure, that will cause DC to increase, because pressure commanded is not being met. Make sense?
Just a thought.
Thanks,
Joey@TE
__________________
15 F350 Crewcab 4X4-Stock!
95 F350 Crewcab 4X4-Terminator HPOS, B codes, Terminator Twin Turbo, and LIVE tuned by DPTuner.
01 F350 SD-Terminator HPOS, and DPTuner.
02 Excursion Limited-Terminator HPOS, DPTuner
97 F350-Wide Open Performance built engine, Big Oil, Twin Turbo(114mm/76mm), DPTuner.
  #80
Old 09-07-2014, 02:37 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to beholdstrokin'_tatsch is a splendid one to behold
Just a thought.
Thanks,
Joey@TE
I've got a set of injectors in my OBS that do that right now. I changed the tunes to command 2700psi to get around it. No more stuttering.
__________________
Travis- Death Row Diesel Inmate #7
1995 F-250 RC PSD- because race truck
2000 F-250 SC LB 4x4 ZF6- 4" exhaust, 6637, TW and Gearhead tunes, 160/100s, Driven Diesel full fuel system, S365 FMW turbo, Irate T4 kit, Valair ceramic dual disc..
1994 F-150 4x4
  #81
Old 09-07-2014, 06:57 PM
Just a thought.
Thanks,
Joey@TE
I swore on the first hill I climbed I was only seeing 2600-2700 psi and the dc was continually raising. I suppose I could have some injector wear. I got the budget stage one upgrade from Jim (no other injector work, just the stage one upgrade) when I did the injectors about 20k ago. They were in good enough shape then according to Jim but that doesn't mean they are now. Maybe its time to pull them and send them to Jim again. The truck has 160k on it.
I shouldn't need to ask for lower psi tunes if I get everything working as it should, correct?
With the melling, wish I would have known that before. I have less bucking problems with this pump than I did with the stock one so it's staying on for now. That in itself makes me believe I'm running the res down as that was the only change made. I also have better oil pressure. Maybe I'm wrong, maybe not. The res spacer is going on anyway.
Thoughts?
__________________
  #82
Old 09-07-2014, 09:44 PM
Thoughts?
If you think its running the res dry, which it shouldn't be, you can remote feed the res from the side of the block into the spacer or the fill plug on top as well. That's what many do a lot of times with dual pumps when they don't want to dump the IPR back into the res.
I'd get the injectors looked at. The pump should have no problem with stage 1s..
__________________
1994 F-150 4x4
  #83
Old 09-09-2014, 05:00 PM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.
We can test the injectors at a higher psi and see how they react if you want.
The flow bench is a great tool but no guarantees that we will find any issues.
If you are able to borrow/use a cut-out box, when it stumbles start shutting the injectors off one at a time and see if you can narrow it further to a single injector. that way if we test and don't find anything, you can try a whole different injector and at least have a direction to go.
Let me know what we can do.
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
  #84
Old 09-09-2014, 07:15 PM
Thanks Jim. It doesn't stumble very much at all, just at the top of those big hills I pulled. It used to stumble more with the stock lpop with lower oil pressure than now, that is the reason I think the res is running dry. There is no way I could test it as it is just one or two bucks now, where before it bucked a lot worse. I don't notice anything at higher icp except for the big hills.
I really don't know what to do. I've got a couple months to figure something out. Would still take any more advice.
__________________
  #85
Old 09-11-2014, 07:06 AM
DZL JIM's Avatar
PREMIUM SPONSOR
I did not read your whole thread, but have you run a mechanical pressure gauge from the top of the HPOil res? This will tell you if the res is running dry.
__________________
DZLJIM.com
  #86
Old 09-11-2014, 09:22 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Quote:
That's a good idea.
__________________
Glenn The Mule-96 2WD F250 EC/LB auto PSD
The Mare 97 dually cc,modified s366 turbo,stage II's,IC,studs,springs,rods,JW auto,4:10 LS,air bags,SD uvch,efuel,FS2500 bypass oil filter,HVHF IDM,IH WP,6.0 trans cooler & rad fan,MBRP 4",SD tensioner,AFE air filter,220 amp alt,38 gal rear tank & 33 gal aux bed tank,aux oil cooler,soundproofed,3 different TS chips,ac cold mod,XS batteries,riffraff hpop reservoir,aluminum radiator,HoneyBadgerJr hpop, water injection
  #87
Old 09-11-2014, 05:25 PM
No, Jim, I have not. That's a good idea, but I'm not going to be making that trip with the trailer anymore this year so there is no way I can now either. I'll be going to the other track at least once more but there are no big hills that way.
Ugh. I wanna take care of this this winter. I postponed my tunes from php for my hydra until I decide what to do.
__________________
Similar Threads
1982 F-150 need ignition switch picture-wire placement-on column cantedvalveFord 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 29 07-31-2013 09:21 PM
engine light on key off..? Nick_lebbad 1987 - 1996 F150 & Larger F-Series Trucks 2 10-06-2012 08:11 PM
32 psi boost good or bad BRay09 6.0L Power Stroke Diesel 32 06-12-2012 08:08 PM
"07" Bucks with cruise on @ 76 mph down hill capehoorn 6.0L Power Stroke Diesel 4 04-26-2009 06:40 AM
starting and charging cashie Electrical Systems/Wiring 17 03-12-2009 02:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
