Roof Mount Antenna
Roof Mount Antenna
Hi,
I have a 74 f350 with a rood mount antenna, as you can see at some point the antenna part broke off. I am looking to replace that part rather than the whole mount but I have no idea where to find the part
If I do have to replace the whole mount can someone recomend a good mount and antenna. I am not looking to do CB or anything just radio.
Thanks
Thanks
That's definitely not a stock item.
They make, or at least used to make, repair antenna masts that bolt on to the broken stub.
You slip it over the stub and tighten a set screw to keep it on place. The '75 I bought as a donor truck had one.
Here's one from O'reilly's
http://www.oreillyauto.com/site/c/de...0201&ppt=C0325
I believe what you are looking for is an NMO mount. They typically run about 15$ locally where I am at, then find a Larson NMO150 antenna for about the same price. The only problem is you will have to redo the end connection from UHF style to whatever that plug is that fits in the back of the radio.
