1962 F250 UniBody 6 cyl Manual 88k miles Should I keep it Stock or Modify? - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 08-03-2014, 06:00 PM
RawDell RawDell is offline
RawDell is starting off with a positive reputation.
How much is my truck worth? 88600 Orig miles. ORIGINAL EVERYTHING
Old 08-05-2014, 07:22 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.Customcab has a very good reputation on FTE.
Each to their own, but me I would make this baby a roadster, sine its a f250
Old 08-05-2014, 09:24 PM
Zooker89 Zooker89 is offline
Zooker89 is starting off with a positive reputation.
For me, the answer is always modify....
Old 08-07-2014, 03:50 PM
TA455HO's Avatar
TA455HO TA455HO is offline
TA455HO is gaining momentum as a positive member of FTE.TA455HO is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by RawDell View Post
ORIGINAL EVERYTHING
You're just kidding, right?
Or did you want me to take a few minutes and describe to you all of the things in just the pictures you posted that are not original? Like the dash cluster bezel and running boards, for instance.
So, you could keep modifying it or put some effort into bringing it back to original. The choice is yours. These trucks are generally not real valuable, except for F250 Unibodys, so you are in luck there.
Old 08-07-2014, 04:13 PM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
I dig the unibodies.
Personally for a truck like this I'm a fan of period correct or hidden upgrades that increase it's usefulness and enjoyability while maintaining the look and feel. But really, what do you want?
Old 08-07-2014, 04:51 PM
Yeah please do point out whats not original...Obviously the cassette player and running lights, but the bezel are you sure?
Old 08-08-2014, 01:52 AM
TA455HO's Avatar
Don't get me wrong, it's not a bad example. For a uni it looks very solid.
I've not seen a bezel like that before. Correct shape, but what is the color or covering on it? I don't think the black painted trim and underneath side of the bezel is original.
The left and right gauges don't look original.
I suspect it had no radio originally since no hole for speaker in dash
Aftermarket radio like you say
Speakers in upper inside cab corners
Carpets
Floor mat
Shift ****
Share your Warranty Plate info and if we can decode that (I don't go back to 1962 yet myself)(and ND has been missing) it might tell us if the seat has been recovered, but I suspect so.
Steering wheel cover
**** on your, what, choke pull?
Something to the right of that that looks like a plug.
The plug to the left of that, just to the right of the steering column IS correct looking.
Door bell button on the steering column to instrument panel connection.
Rocker switch to the left of the steering column hanging under the dash.
There's a hole in the drivers door step riser.
Gas cap is not original
Rear marker lights underneath the tailgate I suspect are not original
Trailer wiring harness
Air cleaner doesn't look original
Radiator hose clamps
Coil doesn't look original. I'd expect a yellow top in many models, but not sure about 1962.
Aftermarket inline fuel filter and clamps between tank and pump?
Clamps on hose between fuel pump and hard line
Bungie cord on battery
What is the battery tray? Might be original but in the picture it looks like it might be a piece of wood. Could be lighting and angle.
Something wrapped around the wiring on the left inner fender (drivers side). Wiring does not look correctly clipped to inner fender.
Wiring to the right of the solenoid looks to be joined using a junction block or bolt in mid air? Hard to tell from the picture.
The gap between your steering wheel and column looks sort of large. Are the horns working using the horn button in the center of the steering wheel like original?
The windshield, I can see Carlite on it so it is probably original. Any cracks in it?
Is the cigarette lighter **** original? Assuming that is the **** on the dash immediately to the left of the steering wheel. It looks a little small.
I can tell it's been repainted some. The striker in the door jamb is painted red and it would have been a silver color like silver cadmium originally.
Wording painted on rear drivers side bed.
Just a few things I noticed. Overall nice truck!
Old 08-08-2014, 10:42 AM
Mmmmm I think you are "guess-timating" or maybe even "speculating". Obviously the 6x9 speakers and the bungie on the battery are not original, and neither is the oil filter btw. Nor some hoses and hose clamps- I changed all that and it's running pretty sweet right now, no problems, just slow.
The truth is I did not buy this truck in 1962. I just bought it less than a year ago. I don't believe you know Exactly what you are speculating about. A few errors- The seat seems to be original, the gas cap is also, using the same original ignition key on it. coil is original. The bezel seems to be particle board, it also had it on both doors, seems to me it was original (i ripped it off the doors-oops). I don't know much how exactly it looked back then, but I believe you don't either. Thanks for your insight tho.
Old 08-08-2014, 01:00 PM
TA455HO's Avatar
Ford did not offer locking gas caps in those years. Read this from NumberDummy (unless you doubt this info from him, which is OK). All gas caps were painted body color, too.
Ford Truck Enthusiasts Forums - View Single Post - Locking Gas Cap
I suspect a locksmith keyed the gas cap to use the same key as the ignition. Nice touch. Or possibly the gas cap and ignition tumbler came from one of the cars ND mentions (Falcon, etc). It's trivial to swap tumblers from one ignition switch to another.
I didn't say your seat material was absolutely not original. I suggested posting the Warranty plate and a decode might indicate if it is or not.
Ford did not use particle board on the bezels or door trims. I would remember something like that. If you can tell me the part number of the particle board bezel from the Master Parts Catalog that would be proof otherwise.
EDIT: I just ordered the 1957-1963 Master Parts Catalog on CD from HiPoParts.com. It'll take a few days to get here but then I can discuss these earlier trucks better.
Old 08-08-2014, 02:58 PM
TA455HO's Avatar
I checked with Don who NumberDummy credits with disassembling more trucks than most line workers assembled and Don says no locking gas caps and no wood bezels. I think milk shot out of his nostrils when I mentioned the wood bezel. He's got a great sense of humor and drinks a lot of milk.
Old 08-08-2014, 05:33 PM
An expert car dismantler, is just that. I still believe that it's original.
Old 08-08-2014, 06:05 PM
TA455HO's Avatar
Just tell us the part number. Don said that will prove your point.
Old 08-08-2014, 06:20 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
C4RZ-9030-C .. Locking Fuel Cap (Motorcraft FC-91) / Obsolete
But the locking fuel cap key is not the same as the ignition key.
The original non locking fuel cap was painted body color, the only "service part replacement" was chrome (B6TZ-9030-A / Motorcraft FC-23).
A previous owner "wood grained" the original painted Standard Cab instrument cluster bezel. It DID NOT come that way originally!
Both the lighter **** and the element are replacements. The original element had the bezel (ash guard) made as part of it, t'was marked LIGHTER
C1TZ-15052-A .. Lighter **** & Element / C1TZ-15054-A .. Lighter Element (only) / 1961/66 F100/1100 / 1963/69 N/NT/T500/1100 / 1967/69 F800/1000.
9030 from 1957/63 Ford Truck Parts Catalog =
Old 08-08-2014, 06:25 PM
TA455HO's Avatar
9030 = 1957/63 Ford Truck Parts Catalog =
Sorry, I should have said they didn't offer it as standard equipment on the assembly line or however you'd phrase it to indicate it was not stock on that truck.
Old 08-08-2014, 06:58 PM
Since the truck does not have a heater, the specific plug (C1TB-18607-A) to the right of the choke cable fills the hole the heater temp/blower switch/cable would have fit into.
Air cleaner is an auto parts store replacement, the original would have been a oil bath.
Seat upholstery is not original, and here's the original battery tray and attaching parts (lower pic)...
Pushrods 72CC428 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 08-01-2016 01:53 PM
Energy Suspension Super Duty 2000-2004 front sway bar bushing kit cpye2 Ford Truck Parts for Sale 5 12-23-2015 07:57 PM
1957-1960 Styleside (fleet) tailgate OEM ORIGINAL PAINT rgs4x Ford Truck Parts for Sale 0 02-02-2015 04:31 PM
LMC Seatbelts. Help. oft 1973 - 1979 F-100 & Larger F-Series Trucks 12 09-23-2014 11:46 AM
can these wheels be saved? roadrash63 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 08-05-2014 01:42 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
