Need part numbers for blend door actuators - Ford Truck Enthusiasts Forums
Old 08-03-2014, 04:20 PM
mdt623 mdt623 is offline
mdt623 is starting off with a positive reputation.
Hello there. I need help locating the right part numbers for the rear blend door actuators for my 2005 Explorer XLT. I had the thumping coming from the rear of the vehicle, and from experience with my previous explorer I knew it was the blend door actuator. I actually replaced the front one on my previous explorer. So I tore into the back and extracted the two actuators to replace them both. I figure that since I was there I should do them together. I pulled them so I could get the exact replacement rather than have to guess and hope. I can find the replacement for one that I am confident with, but the other seems to be a challenge. Here is what I have discovered.
The one I can find replacement for has the model number on it of 2L2H-19E616-AA. This one has the cross shaft. My research has led me to understand that the following are the replacements
Motorcraft YH-1743
Dorman 604-209
dealer replacement is 1L2Z-19E616-BA
My problem lies in finding the replacement for the other one which has the model number 2L2H-19E616-BB. This one has the D-shaft. Can anyone help me track down the proper replacement model numbers for this item.
Thanks
Old 08-05-2014, 05:01 PM
When I posted this it was on Sunday and I could not contact the dealership. I have since made contact with my local dealership and I have the part numbers. I will post them here in case anyone else is looking for them.
2L2H-19E616-AA is confirmed through the dealership as Motorcraft YH-1743
2L2H-19E616-BB is confirmed through the dealership as Motorcraft YH-1746
Hope this helps someone else out.
Old 08-08-2014, 09:49 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
99 Eddie Bauer Expedition Blend door fix lvmilkman2002 Cooling, Heating, Ventilation & A/C 67 03-06-2016 09:37 PM
Where is or how to get to the blend door actuator on 2011 F150 V6? cubangt 2009 - 2014 F150 1 09-15-2013 10:59 PM
Heater / AC Blend Door Actuator (clicking) caughtbasslately Cooling, Heating, Ventilation & A/C 6 11-19-2009 10:17 PM
can someone help me??? caughtbasslately Cooling, Heating, Ventilation & A/C 0 10-24-2009 10:39 PM
rear ac actuator part # help jeremyharraden Expedition & Navigator 6 09-15-2008 01:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
