C6 auto shifts hard into drive
I have a 74' f250 ranger xlt trailer special with a 460 and c6 tranny. Its very difficult to shift from any gear to any other gear it but it goes into gear and stays in gear. Also when you put it in gear it lurches forward. And when your in gear stoped and u get on it you can feel it slip for a split second. I bought this truck as a project its my first car. It starts great and is strong.
Except for the slipping on startup it sounds like either the vacuum modulator is bad or the vacuum line going to it is blocked, disconnected or cracked.
Pull the line of the modulator and see if fluid leaks out, if yes, the modulator is bad. If no fluid leaks out, it still may be bad. Check the line from one end to the other to see if that could be the problem.
Yes it is hard to move to gear selector and when it goes in it lurches foward or reverse obviously depanding on which gear you put it in.
Ok i definatly will thanks for the help
79f100six
10-08-2010 01:04 PM
mrmort
09-07-2004 12:53 PM
Jackflack
10-24-2003 05:31 PM
