Misfire Cylinder 1 7.5l P0301 - Ford Truck Enthusiasts Forums
Old 08-03-2014, 03:55 PM
JonEB JonEB is offline
JonEB is starting off with a positive reputation.
Check engine light came on recently with code P0301. "Cylinder one misfire" I switched wires with adjacent plug (and at distributor cap) reset code, and same code popped up next day. Replaced cap, rotor and #1 spark plug and reset code: same code popped up. Did a compression test on #1 cylinder: 120 lbs which held constant for 10 minutes. (new spark plug doesn't even look like its' seen one explosion in the cylinder - white porcelain and shiny metal after the 40 mile test drive to work and back).
Could it be the injector? ( it ohmed out at 5.7)
Thanks FTE team for any help here.
Old 08-03-2014, 06:18 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
What are you working on?
Old 08-03-2014, 09:21 PM
1997 F250 crew cab with 7.5l (460 cubic inch) gas.
Old 08-04-2014, 06:34 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Moved to 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucks forum
Old 08-04-2014, 07:38 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
Are your plug wires routed correctly and not crossing all over each other? There is actually a recommended routing for them... I've always just run them nice and neat and never had a problem.
I do remember one time I had old plug wires that were failing and causing a misfire under load, but otherwise ran fine at idle and cruise. How old are your wires?
Old 08-04-2014, 12:18 PM
My wires are about 3 months old and higher quality than the budget set. I do however need to clean up the routing with some guides though. I'll try that.
Old 08-04-2014, 01:33 PM
BoKnowsDiesel BoKnowsDiesel is offline
Former Vendor
BoKnowsDiesel is gaining momentum as a positive member of FTE.
The injector should be between 11-18 ohms, so replace the injector
Old 10-30-2014, 11:39 AM
Update: P0301 Misfire Code FIXED!
Thanks to all of the FTE Community help on this one. Replaced the injectors and misfire went away, now she's running smooth, climbing grades AND getting better fuel economy. Best part; bought the injectors for $100 rebuilt on EBay.
Here's a link: injectordyne | eBay
Success!
JonEB
2006 F150 Misfire Cylinder 1 F1504X 2004 - 2008 F150 5 10-15-2016 08:50 PM
P0301 Misfire Cylinder 1 - Number 6 & 9 Misfire Detected Hilt6 Modular V10 (6.8l) 4 07-26-2016 08:49 PM
'05 Expedition - Cylinder 1 misfire super_steve85 1997-2006 Expedition & Navigator 22 07-03-2015 10:50 AM
2005 F150 4X4 P0301 CODE vegas_f150 2004 - 2008 F150 0 06-21-2015 10:24 PM
code P0301 jfp3205 2004 - 2008 F150 1 10-10-2013 08:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
