radio antenna replace - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 08-03-2014, 02:44 PM
countryboy73703's Avatar
countryboy73703 countryboy73703 is offline
countryboy73703 is starting off with a positive reputation.
I messed up the end of my radio antenna that plugs into the back of the head unit. prob going to just have to replace it, I was wondering what path the wire went so that I can run the replaced ment the same way. I would just try to replace the end, but I don't have much slack in the coax cable.. plus the replacement cable is like 35$ or something... any help is appreciated, thanks.
-josh
JBL Antenna cable Spaznaut Explorer, Sport Trac, Mountaineer & Aviator 3 11-29-2016 08:31 PM
Power antenna repair ojh Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 3 06-13-2016 08:39 AM
Antenna cable replacement 67nukeford 1997 - 2003 F150 11 08-30-2015 11:05 AM
Radio and Antenna problems SolusUmbra Ranger & B-Series 4 10-17-2014 09:17 AM
Radio and Antenna problems 1988 Ranger SolusUmbra 1987 - 1996 F150 & Larger F-Series Trucks 1 10-15-2014 10:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
