Cleaning gunk from the crank case? - Ford Truck Enthusiasts Forums
Old 08-03-2014, 11:56 AM
1'stonraceday 1'stonraceday is offline
1'stonraceday is starting off with a positive reputation.
Somewhat unrelated to anything Ford . . . but I know this site has some mechanical geniuses . . . and I need help.
It's a Briggs motor. I use it with a water pump. Apparently the seal went out and there is water in the oil/crank case. The oil's a real pretty off-white!)
What can I put in there to clean all that out? I've heard diesel fuel works very well. Of coarse I wouldn't be starting it, just rotating the crank with starter rope and spark plug removed.
Old 08-03-2014, 11:48 PM
jimbbski jimbbski is offline
jimbbski is starting off with a positive reputation.
Diesel Fuel, Kerosene, or Gasoline will work but the first two are much safer to use. Gasoline vapors can ignite easily with nasty results.
Old 08-13-2014, 05:08 PM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
I've found that nothing beats getting in there with brush or scrapers. But only do that if you're overhauling the engine already.
I opened up a 4 liter v6 in an Aerostar van I bought second hand and found an amazing amount of solid crud in it. It had a one-piece intake manifold gasket, with a wide section that spanned the lifter valley. It looked like someone dumped a cup of cat litter on it. There was a similar collection of crud in the oil pan. No amount of engine flushing would have gotten that stuff out.
Water in fuel already drained keeps coming back ssoulis 1999 - 2003 7.3L Power Stroke Diesel 13 01-11-2016 10:48 AM
Cleaning the crank case? 1'stonraceday General Automotive Discussion 6 08-04-2014 02:42 PM
2001 f-250 7.3 help me crank-it. 250 STROKER 1999 to 2016 Super Duty 2 07-21-2014 11:44 PM
Need help water in fuel. Rishsd 1999 - 2003 7.3L Power Stroke Diesel 31 06-06-2013 07:53 PM
1988 F800 7.8L 474 turbo no fuel - air? brushwolf General Diesel Discussion 8 04-01-2013 07:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
