2010 MOUNTAINEER FRONT END OR AWD VIBRATION. - Ford Truck Enthusiasts Forums
Old 08-03-2014, 10:09 AM
steelers06steelers's Avatar
steelers06steelers steelers06steelers is offline
steelers06steelers is starting off with a positive reputation.
HI GUYS. FIRST LET ME APOLIGIZE AS THIS I GOING TO BE A LITTLE VAGUE. OVER THE PAST MONTH OR SO MY WIFE AND I HAVE NOTICED A SLIGHT VIBRATION OR...??? I DONT REALLY KNOW HOW TO BEST DESCIBE IT OTHER THAN A FEELING. THE TRUCK HAS DEVELOPED THIS FEELING THRU THE STEERING WHEEL AND PEDALS. THE BEST WAY I CAN DESCRIBE IT IS LIKE A BEARING GOING BAD?
IT IS FULL TIME AWD AND I AM ASSUMING IT IS AN AWD ISSUE. THE TRUCK HAS ABOUT 60,000 MILES ON IT. IT CAN BE FELT AT ALL SPEEDS. I ROTATED THE TIRES WITH NO CHANGE.
MY NEXT STEP WOULD BE TO GO THRU THE FRONT END, BALL JOINTS, TIE ROD ENDS, ETC. BUT I REALLY DONT THINK THE ISSUE IS IN THE STEERING. THE TRUCK DRIVES STRAGHT AND NO STEERING VIBRATION.
I AM JUSTWONDERING IF THERE ARE ANY COMMON ISSUES WITH THESE FULL TIME AWD EXPLORERS THAT MAYBE I SHOULD LOOK FOR?
THANKS, DAVE.
Old 08-03-2014, 03:28 PM
took it to church and out to lunch today and I wanted to add a couple things. it is definitely something that is rotational. in other words the sound increases in speed along with the increase in wheel speed. also if I throw the transmission in neutral the issue is still there. the best way to describe the noise would be a rubbing sound but the feel in the steering wheel and floor lead me to believe it is a drivetrain issue. either transfer case or front drive system, maybe a CV joint?
hoping for help....... thanks
Old 08-22-2014, 06:22 PM
Ended up being a wheel bearing, Looking at it now it was very obvious. I tend to over think things sometimes. Thanks for all the help tho.
Took it into the dealer with 59,800 miles on it. The wheel bearing was covered under the 60,000 mile powertrain along with leaking front axle seals.
hooray for me. even a blind squirrel finds a nut sometimes.
Old 08-23-2014, 06:44 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Glad you found the solution to the issue. Just watch the other side now. Occasionally touch the hub to see if it is hotter than the other side.
Sometimes there is a crackling sound at the hub as well.
2004 Lincoln Aviator AWD issues Millinex Explorer, Sport Trac, Mountaineer & Aviator 3 01-19-2017 10:52 PM
1999 Explorer front hub issues? natskend Explorer, Sport Trac, Mountaineer & Aviator 2 04-11-2014 07:39 PM
Removing AWD Escape Driveshaft. 944_s_type Escape & Escape Hybrid 11 04-14-2012 08:59 AM
02 mountaineer front end noise mwkobe Explorer, Sport Trac, Mountaineer & Aviator 9 02-19-2010 08:36 PM
Bad front end vibration in 2000 AWD Mountaineer pilot4x41 Explorer, Sport Trac, Mountaineer & Aviator 4 09-30-2009 12:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
