Little Help Quick Question
Old 08-18-2014, 01:38 PM
Hop16's Avatar
Hop16
Hop16 is offline
Ok so I'm replacing the 4.6 in my 03 explorer at this point motor is sitting in the mounts, transmission is on the dowels all the bolts in the bellhousing finger tight roughly 1/4 to 3/8 gap and still can't locate the torque converter studs am I not close enough messed up gone to far? Please drop some words of advice of possible
Old 08-18-2014, 03:27 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
The studs are prob pressing against the flywheel and they are turning together. Loosen the trans mount and slide the trans back as far as it will go to get a little more room. You may need to wedge something against the torque converter to keep it from turning while you turn the engine. Once you get it lined up and the trans tight against the engine the torque converter should be able to rock back and forth slightly in the flywheel holes. If it doesn't then something is in a bind.
Old 08-18-2014, 04:11 PM
Hop16's Avatar
Hop16
Hop16 is offline
OK thank you will give it a try here shortly if the rain will go away
Old 08-21-2014, 05:20 PM
Hop16's Avatar
Hop16
Hop16 is offline
So I'm having difficulty locating the torque converter as I look the holes for the studs appears everything is rotating together and starter hole plug on the driver side and inspection cover see no where to get anything fingers eyes on somewhere to hold or wedge the torque converter
Old 08-21-2014, 08:50 PM
70f100longbed
Maybe pry the engine and trans apart with a large screwdriver while turning the torque converter with a finger, it's a PITA but you got to line it up somehow. Did you slide the trans back?
Old 08-22-2014, 03:14 PM
Hop16's Avatar
Hop16
Hop16 is offline
Yes trans is slide back if the weather plays nicely tomorrow I'm going to float the motor again and see what type of space I can get hope to have it figure out soon just going to need some weather to hold out for me as I'm working outside
Any other suggestions I'm open to all lesson!
Old 08-22-2014, 03:21 PM
70f100longbed
Are all of the bellhousing bolts lined up?
EvoDawg
Engine Swaps
12-05-2009 08:13 PM
THE KING
09-18-2006 03:29 PM
DocMel
05-15-2006 07:10 AM
smallblock351w
04-02-2006 07:48 AM
kvb78
04-24-2004 10:05 PM
Quick Reply: Little Help Quick Question
