On your first post back in March you said you found one but it wasn't working "lining up" with anything.
So now your looking for the same part again?
I was just doing a quick search for you to see if I could come up with one here in NoCal.
But then I found your old thread and cant figure out exactly what you need. Sorry. Maybe you can post a pic. ?
If looking for a temporary fix until the item is located, when I purchased the 65 in the later 70's the prior owner installed a 302 and said he had always had an issue with the Z-bar alignment. At the first opportunity, I took the appropriate width spacers, not washers', and placed them between the bracket and the frame, so what was originally a temporary solution has been working fine since. Anyhow, something may want to consider in the interim ???
